Batch Status Stuck in Updating
  • Batch Status Stuck in Updating
    Posted by DSC Communities on May 9, 2019 at 9:31 am
    • Stefanie Tichacek
      May 9, 2019 at 9:31 AM
      Hey GPUG,
      We’ve got a Financial batch stuck in “Updating” status. When we run trial balances, it looks like all of the transactions have posted, yet the batch remains. Tips on how to fix this? Also, what causes this to happen?
      Thanks for the help!
      Stefanie Tichacek
      Nashville
    • Ryan Galang
      May 9, 2019 at 12:39 PM
      Hi Stefanie,
      Can you see if you’re able to reset the status of the batch via Batch Recovery? If yes, print the Edit List next… this may confirm if the transactions have been posted… You can also use the Inquiry windows to verify this.
      If they are, then you might just need to delete the batch… (it’s possible that the posting interruption took place after the posting, prior to the “batch cleanup”). Take note though, that a batch can only be deleted when it’s status is “Available”.
      If the status does not get reset to Available – using a SQL script would be the next option…
      Ryan Galang
      BTP Technologies LLC
      Chantilly VA
    • Stefanie Tichacek
      May 9, 2019 at 1:03 PM
      Hi ,
      Thanks for the input! Unfortunately, nothing is displayed in batch recovery. Any suggestions on a SQL script to run??
      Stefanie Tichacek
      Nashville
    • Steve Burney
      May 9, 2019 at 2:56 PM
      One thing to do first is to access this website and save it, if you have already done so.
      GP Tables
      Victoria Yudin remove preview
      GP Tables
      Below are pages with table information for Dynamics GP as well as some additional resources for finding table information. This is not meant to be a listing of all tables or all modules, just the tables and fields we most often use when reporting.
      View this on Victoria Yudin >
      Open the Company/System Tables option to see the BCHSTTUS options.
      Once you are logged in you SQL server and the database you are using, then you can run this statement to get you started.
      Select * from SY00500
      where bachnumb =’Your batch number’ and see what the settings are for BCHSTTUS setting of this batch.
      This will give you an idea of what the current standings are and should help you move forward with clearing this issue.
      I hope this helps you and let us know if more assistance is needed.
      Steve
      Steve Burney
      Senior Systems Architect
      Nissan Trading Corporation, Americas
      Lebanon, TN United States
      steve.burney@us.nitco.co
      Chairman, Nashville (TN) GPUG Chapter
      GPUG Ruby Award 2018
      GPUG All Star 2017
      Twitter @SteveBurney
      GP2016 R2
      MRCU14
      May 9, 2019 at 5:37 PM
      Hi ?
      Deleting/removing the batch name from the SY00500 is one of the last things done in the GP Code Processing during batch posting.
      Since you are posting batches and it seems to work, but the batch name is not being deleted, then it seems like what may be happening is that the posting is “not finishing” for some reason.
      If you run the script:
      SELECT * FROM GL10000 WHERE BACHNUMB = ‘YOUR BATCH NUMBER
      This is to look for amounts in the Financial Batches only.
      If nothing is there then something may be interrupting the batch posting process and this could be a crazy amount of things, including users shutting down before the last bit has happened to an installed third party or customization getting in the way.
      Check on this and let us know what you find.
      Jo deRuiter, MCP, DCP
      “That GP Red Head”
      770-906-4504 (Cell)
    • Aleiha Hanson
      May 9, 2019 at 3:29 PM
      we’ve had similar things happen…these have worked for us. First, I would run scripts to check if anyone has a stuck SQL batch.
      This one is safe to use while users are still logged in:
      Ā  Ā  Ā SELECT * FROM DYNAMICS..ACTIVITY where USERID not in (select loginame from master..sysprocesses)
      Ā  Ā  Ā SELECT * FROM DYNAMICS..SY00800 where USERID not in (select USERID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā SELECT * FROM DYNAMICS..SY00801 where USERID not in (select USERID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā SELECT * FROM tempdb..DEX_LOCK where session_id not in (select SQLSESID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā SELECT * FROM tempdb..DEX_SESSION where session_id not in (select SQLSESID from DYNAMICS..ACTIVITY)
      If all looks ok, then run the delete.
      Ā  Ā  Ā delete DYNAMICS..ACTIVITY where USERID not in (select loginame from master..sysprocesses)
      Ā  Ā  Ā delete DYNAMICS..SY00800 where USERID not in (select USERID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā delete DYNAMICS..SY00801 where USERID not in (select USERID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā delete tempdb..DEX_LOCK where session_id not in (select SQLSESID from DYNAMICS..ACTIVITY)
      Ā  Ā  Ā delete tempdb..DEX_SESSION where session_id not in (select SQLSESID from DYNAMICS..ACTIVITY)
      Then, I would also run a script to “unlock” the batch you were trying to post.
      Ā  Ā  Ā  Ā  >>>unlocking a batch that is stuck as marked by other user but not in batch recovery screen:
      Ā  Ā  Ā  Ā  UPDATE SY00500 SET MKDTOPST=0, BCHSTTUS=0 where BACHNUMB=’XXX’ ?
      ALWAYS proceed with caution when running any scripts and ALWAYS create backups when possible before running any update/delete scripts.
      Aleiha Hanson
      Royal Basket Trucks, Inc – IT Manager
      GPUG Milwaukee WI Chapter Leader
      ahanson@royal-basket.com
The discussion ‘Batch Status Stuck in Updating’ is closed to new replies.
