Bank Transactions Not Posting to General Ledger
  • Bank Transactions Not Posting to General Ledger
    Posted by DSC Communities on May 14, 2018 at 9:46 am
    • Becky Wollner
      May 14, 2018 at 9:46 AM
      Good Morning All-
      We posted a bank transaction through GP and it has not posted to the General Ledger and now our accounts are not reconciling because of that transaction.Ā  The transaction did post through the bank reconciliation module and has since been reconciled for April.Ā  Because of this, we can no longer void the transaction.Ā  I am unsure how to push the transaction through to the general ledger.Ā  Currently, our sub ledger and ledger are not tying out.Ā  Ā Are there any suggestions or work-arounds?
      Becky
      Becky Wollner
      Spaulding Clinical Research, LLC
      West Bend
    • Cecile Dinh
      May 14, 2018 at 11:21 AM
      ?Hi Becky,
      If you go to Setup >> Posting >> Posting >> Financial >> origin:Ā  Bank Transaction Entry, do you see Post to and Post Through checkboxes marked?
      Have you checked all unposted batches in GL?Ā
      You can also try to run Reconcile by going to Tools >> Utilities >> Financial >> Reconcile.
      If still not resolved, you can just enter an adjusting Journal Entry in GL – and make a note that is your Bank Transaction entry with reference number.
      That will tie up your GL and Bank Recon.
      Hope this helps.
      Cecile Dinh
      Microsoft Dynamics GP Administrator
      ARC (Airlines Reporting Corporation)
      Arlington VA
    • Becky Wollner
      May 14, 2018 at 11:45 AM
      Thank you for the response.Ā  If i got to the set-up that you listed, the post to general ledger field is checked, but the post through to general ledger files is not.Ā  Based on your response, I would guess they should both be checked.Ā  Ā Do you know what the difference between those two fields?
      Becky Wollner
      West Bend
    • Bert Green
      May 14, 2018 at 3:58 PM
      Becky,
      The post to gl creates the batch in Financials.
      The post through gl actually takes the batch and posts it.
      If you look in Financials > Series Posting you might see a batch that has not been posted that will be for the bank transactions. Would start with a CMTRX I believe.
      Bert Green
      GP Developer/GP Administrator
      Saint Paul MN
      GP2015/MR CU11
      GPUG All Star 2017
    DSC Communities replied 7 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Bank Transactions Not Posting to General Ledger’ is closed to new replies.
