Attaching documents to vendor cards
  • Attaching documents to vendor cards
    Posted by Ben Micek on April 3, 2018 at 12:15 pm
    • Ben Micek
      April 3, 2018 at 12:15 PM
      ?Hello,
      I am wanting to attach our vendor forms ( W9’s) to the vendor card in GP 2015. Can anyone explain the process of doing this? Any help would be appreciated
      Thank you
      Ben Micek
      Ben Micek
      Accounts Payable
      Outlook-Nebraska, Inc.
      Omaha NE
      April 3, 2018 at 1:36 PM
      ?Hi
      To be able to use the document attachment you first have to configure doc attach in the system settings.
      Here is a quick screenshot and the window will look different – I’m using GP2018, but ?the settings are pretty self explanatory.Ā  If you have any questions, with the window open click on help (on the window) and “about this window”
      After you configure this you will be able to attach documents in the vendor card.Ā  A little blue paper clip will appear and you click on that and you can attach.
      Additionally, if you do not want to use the doc attach, in some versions you could attach files at the Note level – you open a note and there is an attach document button.
      Kindest Regards,
      Jo deRuiter
      “That GP Red Head”
      Milwaukee, WI
      770-906-4504 (Cell)
    • Ben Micek
      April 4, 2018 at 11:01 AM
      ?Does this require having a scanner or can I just use our printer and send the forms to myself?
      Ben Micek
      Accounts Payable
      Omaha NE
    • Michael Gummel
      April 5, 2018 at 8:42 AM
      if you have a scanner you can use, but if not then you can select the file using windows explorer to select the file
      if you send the form to yourself, you’ll need to save it somewhere either on your computer or network
      Michael Gummel
      Prod Engineer
      Paradigm Technology Consulting
      Allentown NJ
    Ben Micek replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Attaching documents to vendor cards’ is closed to new replies.
