Adding Labor Cost Sum to a Manufacturing Order
  • Adding Labor Cost Sum to a Manufacturing Order
    Posted by DSC Communities on May 10, 2017 at 10:40 am
    • Jeffrey Abood
      May 10, 2017 at 10:40 AM
      Hi – we are looking for a way to add one total lump sum cost of labor to an MO…we currently are working on configuring all of the labor cost functionality but in the mean time, we were hoping for an easy way to apply the total cost that we’ve manually calculated into the MO upon MO Completion.
      Anyone have any ideas?
      Thank you!
      Jeffrey Abood
      GourmetGiftBaskets.com
      Exeter NH
    • Tom Monfre
      May 11, 2017 at 5:01 PM
      Jeffrey,
      You may want to look at the Data Collection window, Manufacturing->Transactions->WIP->Data Collection.  You would need to do some setup but I think this will do what you want.  Enter MO Number, Sequence and select Direct Labor for Data Collection Type.  You’ll need to select an Employee and Labor Code along with Pay Code of Direct.  Enter the Start and End date and time to calculate the total labor hours.
      Feel free to contact me if you have questions.
      Tom Monfre
      Batteries Plus Bulbs, LLC
      Hartland WI
    • Fred Hartman
      May 12, 2017 at 10:06 AM
      Hi Jeffrey,
      There are numerous ways to add labor cost to MOs in GP Manufacturing.  The “best” way for your needs depends on how you are set up, how you transact MOs, how you want your financials to reflect the labor cost, etc.
      You could actually add the labor cost in the final MO Receipt step if you really only want to add labor cost at MO Completion (MO receipt).
      “Better” would be to add a labor entry on the routing – how & where depends on how you want cost to happen and flow – but it’s easy and simple to add some labor cost to the routing and set up a generic labor code, flag for backflush, and the addition of labor cost is normal simple and easy to transact.
      I’d be happy to coach you through this, give me a call 302-479-5068.
      Fred
      Fred Hartman
      Principal
      Hartman Consulting (specializing in GP Manufacturing consulting)
      Wilmington DE
    DSC Communities replied 7 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Adding Labor Cost Sum to a Manufacturing Order’ is closed to new replies.
