AA codes User Access
  • AA codes User Access
    Posted by Monya Maccio on February 26, 2020 at 3:44 pm
    • Monya Maccio
      February 26, 2020 at 3:44 PM
      Hi there,
      is there an easy way to give AA TRX Codes Access to a user without going through each TRX dimension?
      I mark all under distribute and adjust but I still have to save and scroll through each TRX Dimension code.
      TIAĀ
      šŸ™‚
      Monya Macció | IT Business Applications Manager | Kroenke Sports & Entertainment
      Pepsi Center, 1000 Chopper Cir, Denver, CO 80204 USA
    • Samantha Higdon
      February 27, 2020 at 6:25 AM
      Good Morning ,
      There are three options I can think of:
      1.) If you want ALL users to have access to ALL dimensions, you can simply uncheck the box in your window that says “Restrict User Access”.Ā  That will override whatever individual security settings you have by dimension and give all users (with access to AA) access to the dimensions.
      2.) You could do something in SQL – a stored procedure or trigger of some kind – to run it on the back end, but that would take a bit more refining of the “ask” here to make sure the procedure or trigger did exactly what you wanted and not more.
      3.) GP 2018 introduces a new button on the window you’re displaying that allows you to copy AA access from one user to another.Ā  Do you happen to know what version of GP you’re on?Ā  If you’re on GP 2018 or newer and still don’t see it, you might look into whether your security’s been adjusted or the form’s been adjusted to hide the button.
      Does that make sense?Ā  If there’s anything else, just let us know.
      Samantha
      Samantha Higdon ,CPA,CGMA
      Consultant
      Lagom, LLC
      Carmel IN
    • Monya Maccio
      February 27, 2020 at 10:35 AM
      Thank you Samantha!
      We’re on GP 2016 and unfortunately I don’t have the button you suggested. We have to restrict user’s access but I’ll try to work something in SQL.Ā
      I’ll keep you posted.
      I appreciate the help!
    • Charles Allen
      February 27, 2020 at 10:02 AM
      There is. I’ve attached a trigger that can automatically assign new dimensions to users.
      Charles Allen
      Senior Managing Consultant
      BKD Technologies
      Houston, TX
    • Monya Maccio
      February 27, 2020 at 11:44 AM
      Charles, thank you so much for your response!
      We tried and completed successfully but it didn’t change anything. Do we need to change the aaTrxDimID and TrxDimCodeID as well?
    Monya Maccio replied 6 years ago 1 Member · 0 Replies
The discussion ‘AA codes User Access’ is closed to new replies.
