As Jo stated, it’s a very bad idea to change the GP table schema and field definitions.. at every next upgrade you run the risk to scrap your customizations as the table might get recreated in the process of upgrading.
Another alternative to use the eOne Extender product is GP PowerTools and the developer module.. With modifier you can add new fields into existing forms and populate the data with a code logic in GPPT. I agree that it requires more programing skills than using Extender, which is also easier to query data from later on.
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
