Zero cost on a count journal- Need Fix
  • Zero cost on a count journal- Need Fix
    Posted by Unknown Member on January 21, 2020 at 5:15 pm
    • Ryan Bacon
      January 21, 2020 at 5:15 PM
      In AX 2012, we had a count journal that posted physical quantities with no physical/financial cost.Ā  How would I go about assigning a cost to those transactions?Ā  If we do an inventory adjustment after inventory close, will that post in the period closed or the next month?
      Ryan Bacon
      CountryMark
      Mt. Vernon IN
    • AndrĆ© Arnaud de Calavon
      January 22, 2020 at 11:49 AM
      Hi Ryan,
      Depending on the inventory costing model, you can manage the cost in multiple ways. If there is a deduction as result of the counting, you can’t change the posted cost. That is part of the inventory posting logic.
      When you have a positive quantity, the cost will be taken from the item information. If this is not set, you can manage it on the journal. When it has been posted already, there is a cost adjustment option part of the inventory closing and recalculation.
      kind regards,
      AndrƩ Arnaud de Calavon
      Product manager, Microsoft MVP – Microsoft Dynamics Business Solutions
    • Troy Jones
      January 22, 2020 at 11:51 AM
      Ryan:
      I hope you and Countrymark are doing well.Ā  I noted both your issue and your company.Ā  I was one of your original implementers of DAX back in the 2009 version.Ā
      That being said, you might have some documentation on the old folders I wrote on how to do this exact process for your former controller using the IM-Periodic-Closing and Adjustment – Adjustment-Transactions.Ā  It is the same process in AX2012. Ā
      If you need to, just email me through here and I can connect with you to check if I still have it and can email it back to you. Hope this helps and look forward to prospectively helping you resolve this.Ā
      Sincerely,
      Troy Jones
      Functional Systems Architect / Consultant
      Hi-Vue Solutions, LLC
      Akron OH
    Unknown Member replied 5 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Zero cost on a count journal- Need Fix’ is closed to new replies.
