Using Atlas to Import into Hours Journal
Posted by DSC Communities on February 17, 2020 at 6:35 am-
Mathew Frost
MemberFebruary 17, 2020 at 6:35 AM
Hi all,I’m looking to see if it’s possible to import records into the Hours Journal of our AX 2102 r3 system from a CSV/Spreadsheet.
The screens in AX I’m interested in importing into are the “Hours Journal” for the header record and then the “Journal lines for hours” screen for the lines that make up the details of the header. Examples of data below.
As far as Excel/CSV file format, I could be fairly flexible.
I’m quite inexperienced with Atlas and have never used it for an import before and have only been working with AX for a month now but I am a full admin with a full Atlas license so shouldn’t have any problems having the correct requirements.
I’ve tried to guess my way through the process in Atlas and AX to work out what i’d need to do and I believe what I need to be looking at is ProjEmplTrans table but I’m really unsure how it works with regards to creating a header record and then importing all the lines into it.
Any ideas if what i’m trying to do is actually possible? If it is, would anyone be so kind as to lend some advice or point me in the right dirrection for assistance. If it’s not possible, could someone tell me and stop me from wasting anymore time on it, haha.
Many thanks!
Mathew Frost
Lawrence David Ltd
Peterborough
Guy Terry
MemberFebruary 18, 2020 at 1:59 AM
Hi MathewAs a licensed customer, I think you should have no trouble getting access to the Atlas on-line resources.
https://help.insightsoftware.com/s/login/SelfRegister
This site has many pre-built upload templates that you can download (although I could not find one for Project Hours). But it also has training resources (search Atlas Getting Started). For the header/lines type upload you need, I imagine you’ll be wanting to use a Journal upload type in Atlas.
If you need help registering, try contacting their support:
Guy Terry
Application Consultant
Annata
Portsmouth
Chris Burton
MemberFebruary 18, 2020 at 6:42 AM
I’ve just had to do this and I based it on a template from Global.I tweaked it to match my requirements but the basics are the same.?
Chris Burton
Application Business Partner
RNLI
Poole
Mathew Frost
MemberFebruary 18, 2020 at 7:14 AM
Hi Chris,That sounds really reassuring, thanks so much for confirming. I unfortunately don’t have an account with Global and am not going to be able to get one so I cant follow your link unfortunately.
Would you be willing to share the file privately with me? I’d be so incredibly grateful!
Many thanks for considering. š
Mathew Frost
Lawrence David Ltd
Peterborough
Hi Mathew,
Our new customer portal is located at http://help.insightsoftware.com. Any customer current on software maintenance can register to create an account at that site. There you’ll be able to access the template library, software downloads, training materials, etc.
If you have any trouble creating an account, reach out to me and I’ll get you connected to your account manager.
Jason——————————
Jason Carter
Solutions Enablement – Atlas
Global Software LLC dba insightsoftware
Fargo ND
DSC Communities replied 5 years, 6 months ago 1 Member · 0 Replies -
The discussion ‘Using Atlas to Import into Hours Journal’ is closed to new replies.
