I am wondering if some of you have had issues with the Trial Balance report
In one of the companies I am handling the Trial Balance is not showing correct balances for the last three months.Ā My question is if there something I can do to correct it?
When I run the defined trial balance using the financial reports is showing correct.
—————————— Alexis Barrios Fyffes Group Ltd Pompano Beach FL ——————————
Are you using Dynamics 365 or AX2012? Are you using the Trial balance inquiry form/report or a report defined under ‘Financial reports’ (Management reporter)? If you are using the inquiry form, try to rebuild the balances for allĀ Financial dimension sets. If it is Management reporter, try to reset the data mart database.
In the trial balance form can you check if you see any data when you select “Include Closing transactions in balances” and/or “show opening transactions in opening transaction column” checkboxes available from the Trial balance Column to display form on action pane.
Also when you rebuild the balances did you enable that in batch?
I actually just had this happen to me as well – we reversed some transactions and although the detail was right, the TB totals were wrong.Ā We tried rebuilding and updating but the only thing that fixed it for us was completely clearing the financial set balances and then recreating.Ā I don’t know why updating or rebuilding alone didn’t fix it, but you might try that as well.
—————————— Shirley Adams Solution Architect AKA Enterprise Solutions New York NY —————————— ——————————————-
