Total cost of the production. Raw material + subcontract
  • Total cost of the production. Raw material + subcontract
    Posted by DSC Communities on February 8, 2018 at 5:02 pm
    • Lisa Ng
      February 8, 2018 at 5:02 PM
      Hi All,
      I need to order the materials; then send those materials to a manufacturer A to produce a product A.Ā  Ā After finished, the manufacturer A sends the product A back to me.Ā  Then I send the product A to another manufacturer B to make the product B.Ā  Then I receive product B.Ā  How doĀ I tract the total cost of the production?Ā  I’m assuming I would create:
      1.Ā  an Item for a material.Ā Ā
      2.Ā  an item for Subtract A
      3.Ā  an item for Subcontract B
      Step process:
      When the customer placed an order, I would think I need to create a production order:Ā  Estimate->Release->Start.Ā  At the point of “Start” the production, will I see the inventory or materials to move out of my book? (reduce inventory).Ā  How do I move the materials to the manufacturer A?Ā  I don’t think I just simply write a journal entry; because I can’t track my item that way.Ā  Can I?Ā  Will the materials sit in my production when I don’t produce the product?Ā
      When I hire a manufacturer A to make the product A, I wouldĀ think I need to place a PO.Ā  When I receive the finished product A from the manufacturer A, then I “Receipt” it.Ā  At this point, I go to the production, and click on “Report as finished”, correct?Ā Ā
      Could someone please shed some lights to this process?Ā  Thanks so much!
      Lisa Ng
      Business Analyst
      HOUSTON TX
    • Jonathan Anderson
      February 9, 2018 at 8:42 AM
      Lisa,
      The version of AX that you’re on, along with whether you are using routes or not will have an impact on the answer to this question.Ā  So can you please let me know what version you’re on and if you’re using routes?
      Jonathan Anderson
      Managing Consultant
      BKD Technologies
      Denver CO
    • Lisa Ng
      February 9, 2018 at 10:26 AM
      Hi Jonathan,
      Thank you for your response.Ā
      The version is D365.Ā  I would think I need a route.Ā Ā A route contains the set of operations that are required to produce a product or an item.Ā  Is there a situation that the route is not required in production?Ā  Ā Ā
      Lisa Ng
      Business Analyst
      HOUSTON TX
    • Jonathan Anderson
      February 12, 2018 at 8:51 AM
      Lisa,
      Yes there are some production companies that use AX that don’t want to go through the process of maintaining routes, resources and calendars.Ā  They utilize the inventory lead time on the item for master planning purposes and then apply an overhead cost through the costing sheet to account for the manufacturing costs of the parts.
      Since you’re using route, what I would suggest you do is create the following parts:
      1.Ā Ā an Item for a material
      2.Ā  an item for Subtract A part
      3.Ā  an item for Subcontract A service
      4.Ā  an item for Subcontract B part
      5.Ā  an item for Subcontract B service
      Subcontracting requires the material being used and the service provided in the BOM.Ā  The service is tied to the vendor record and the subcontract route operation, and creates a purchase order for the service automatically when estimatingĀ the order.Ā  Then when the service PO is received that route operation is completed by the system.Ā Ā
      The youtube video below (while short) goes through the process of subcontracting in AX.
      Microsoft Dynamics AX 2012 Production – Sub Contractor Work Overview
      Jonathan Anderson
      Managing Consultant
      BKD Technologies
      Denver CO
    DSC Communities replied 7 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Total cost of the production. Raw material + subcontract’ is closed to new replies.
