This lead is closed. You cannot convert or disqualify a lead that is already closed.
This lead is closed. You cannot convert or disqualify a lead that is already closed.Follow
Karen Bebow
Karen BebowApr 06, 2022 11:34 AM
Is there anything we can do to be able to qualify a lead that was disqualified? Thank you! —————————— …
1. This lead is closed. You cannot convert or disqualify a lead that is already closed.GOLD CONTRIBUTOR
Karen Bebow
Posted Apr 06, 2022 11:34 AM
Is there anything we can do to be able to qualify a lead that was disqualified?Thank you!
Karen Bebow
Information Systems Manager
Powell Fabrication & Mfg LLC
St. Louis MI
——————————2. RE: This lead is closed. You cannot convert or disqualify a lead that is already closed.
TOP CONTRIBUTOR
Donal McCarthy
Posted Apr 07, 2022 02:32 AM
Sure, reactive the lead and you should be able to qualify it.——————————
Donal McCarthy
BrightWork
Galway
——————————3. RE: This lead is closed. You cannot convert or disqualify a lead that is already closed.
GOLD CONTRIBUTOR
Karen Bebow
Posted Apr 07, 2022 08:18 AM
Hi Donal,Thank you for the reply! When we select a lead, we do not appear to have the Reactivate Lead option. Attached is what we see.
No Reactivate Lead option——————————
Karen Bebow
St. Louis MI
——————————4. RE: This lead is closed. You cannot convert or disqualify a lead that is already closed.
SILVER CONTRIBUTOR
Rick Jarvis
Posted Apr 07, 2022 08:32 AM
there is an out of the box reactivate button. Perhaps this was removed from your tool bar or constrained by securityEither way, if you reactivate, you may also need to reset the process
Rick Jarvis
Manager, Sales Operations
Kraton Chemical
Jacksonville FL
——————————5. RE: This lead is closed. You cannot convert or disqualify a lead that is already closed.
GOLD CONTRIBUTOR
Karen Bebow
Posted Apr 07, 2022 08:47 AM
Well, how embarrassing! 🙂The issue was that the upper menu that you highlighted is taking about 15 – 20 seconds to load. I wasn’t waiting that long, but was instead going back to the list of leads and looking for the reactivate button there. I assumed there wasn’t a menu within the lead that I opened because it was read only. Wow – I need some more coffee!
Thank you so much for each of your replies. I appreciate it!
Karen
Karen Bebow
St. Louis MI
——————————6. RE: This lead is closed. You cannot convert or disqualify a lead that is already closed.
TOP CONTRIBUTOR
Donal McCarthy
Posted Apr 07, 2022 08:43 AM
What does the toolbar look like when you open the disqualified record? – the screenshot you’ve shared looks like the view toolbar.——————————
Donal McCarthy
BrightWork
Galway
The discussion ‘This lead is closed. You cannot convert or disqualify a lead that is already closed.’ is closed to new replies.
