The value 1 is not found in the map. Error message
  • The value 1 is not found in the map. Error message
    Posted by nazimlalji@hotmail.com on June 17, 2018 at 7:21 pm
    • Najeem JanatAli
      June 17, 2018 at 7:21 PM
      HiĀ
      Error message “The value 1 is not found in the map” when opening GL parameter (under GL set form) form in AX 2012 R3
      May I ask whats the reason of this error message and how it incurred
      please advise to resolve this
      thanks
      Nazim Lalji
      Dynamics AX Analyst
    • AndrĆ© Arnaud de Calavon
      June 17, 2018 at 11:59 PM
      Hi Nazim,
      Can you tell if you have any customizations in this area or recently installed om this environment? Try to do a full compilation (both x++ and CIL build) and thereafter a database sync. If this does not help, you can use a debugger tool to find the culprit.
      kind regards,
      AndrƩ Arnaud de Calavon
      Solution Architect, Microsoft MVP – Microsoft Dynamics Business Solutions
    • Rick Pierson
      June 18, 2018 at 9:42 AM
      One reason (not the only one) that error occurs is if you are using a progressBar and you don’t call setTotal().Ā  If you have added a customization that uses a progressBar at that point (doesn’t seem really likely), then here is a link to Martin Drab’s post about it.
      https://community.dynamics.com/ax/b/goshoom/archive/2015/03/21/the-value-1-is-not-found-in-the-map
      Rick Pierson
      Braun Intertec
      Bloomington MN
    • Najeem JanatAli
      June 18, 2018 at 3:11 PM
      HI Andre
      The following message has been sent to you in response to your Discussion message
      Message From: Nazim LaljiĀ
      Hi Andre
      there is no customization done.
      it was server maintenance that may be the reason of this issue!
      Restarted the AOS services, that fixed this issueĀ
      However when did the Data sync, some SQL error info log came up
      So far AX is working
      any suggestion
      thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    nazimlalji@hotmail.com replied 7 years, 2 months ago 1 Member · 0 Replies
The discussion ‘The value 1 is not found in the map. Error message’ is closed to new replies.
