SSRS report creation Wizard
  • SSRS report creation Wizard
    Posted by DSC Communities on February 2, 2017 at 12:46 am
    • Tanuj Goel
      February 2, 2017 at 12:46 AM
      Those who have worked in Ax2009 are aware of the Auto design Morphex report creation wizard. There is nothing like that in Ax2012. OnActuate has come up with a wizard which can create the following artifact automatically
      1) Query – In case Query in not existing then query is created for all the datsoruces specifed through wizard. Option of specifying the range and sort fields is also provided
      2) Contract class- Contract class with any number of parameters.
      3) DP class – DP class with setting of above mentioned contract and Query. Also the logic where contract class parameters are applied on the datasource fields. Assignment of datasource fields to temporary table fields in processreport method.
      4) Temporary table – Temporary table creation with all selected fields from the daatsoruce in the wizard
      5) Auto design SSRS report – Auto design SSRS report, either based on Query or on DP class
      6) Deploy the report – Automatic deployment of the report.
      As you can guess lot of time is going to be saved using this wizard. Those who are using the tools like BottomLine Create Form can find it really handy because framework of that tool needs all above before designing can be done.
      Tanuj Goel
      OnActuate Consulting
      OAKVILLE ON
The discussion ‘SSRS report creation Wizard’ is closed to new replies.
