Current requirement is changes made in both database and application, please can you advise the path in AX 2012 R3 or what which area in AOT to pull this report
Also if you can specify what are the other requirement falls under SOX 404
Database changes will have to be done either by the database log or by an external tracking software. I will advise that the database log within Dynamics AX was never meant as an audit tool, it was built as a debugging tool. You will see a performance decrease if you enable this feature for any number of tables. There are also very few native reports and data management capabilities built into the tool itself.
But also keep in mind that you will not be able to track every change that is occuring in the database, you want to take a ‘risk based approach’ to what you are tracking and making sure that there is an audit requirement for tracking that change. By doing this you help improve system performance and minimize the amount of data you need to track and report on.
As far as other audit requirements go, you may also be needing Segregation of Duty reports I’ve actually written a white paper about the gaps in Microsoft’s SOD platform that auditors will ask about. It can be found here:Ā Fastpath vs. Dynamics AX/D365FO Segregation of Duty Analysis Comparison
If you have further questions feel free to reach out, I would be happy to answer them.
—————————— Alex Meyer Director of Dynamics AX/365 for Finance & Operations Development Fastpath Des Moines, IA —————————— ——————————————-
Lori Hodsoll
June 13, 2019 at 11:38 AM
Hi Nazim,
I used FastPath at my last company.Ā It offers a lot, especially if you put in the effort to configure it to get what you’re really looking for.Ā Feel free to reach out if you want the customer perspective.
—————————— Lori Hodsoll Supernus Pharmaceuticals Rockville, MD —————————— ——————————————-
