Sending docs (invoice, confirmations, etc) via email
  • Sending docs (invoice, confirmations, etc) via email
    Posted by DSC Communities on December 17, 2018 at 1:08 pm
    • Justin Cooper
      December 17, 2018 at 1:08 PM
      First, I want to thank everyone for the help lately. D365 is a new beast for me (ERP systems in general are new to me) and I have had our D365 environment fall into my lap.
      I was able to get print management setup so that invoices can be sent out via email directly from D365. The problem we have now is that there is no way to edit the body of the email, so our customers receive an email with the invoice attached and a generic subject line.Ā
      Is there a way to either a: when you choose the option to send the email, have it launch outlook with the file attached (I understand that there are some documents that allow this capability) orĀ  b: customize the body of the email to at least have generic text, without having to go in and have custom code?
      Justin Cooper
    • Andrew Lencsak
      December 17, 2018 at 3:25 PM
      Hi Justin,
      Have you looked into the Organization administration module, where you have Email templates under the Setup section. These templates can be setup to include the body content and header subject you want to use. They can have wildcards as part of this setup to include fields like PO or SO number, vendor number or customer number, etc. as well as the “generic” body you want the receiver to see in the email.
      Andrew Lencsak
      Senior Application Consultant/Solution Architect
      eBECS Limited
      Atlanta GA
    • Justin Cooper
      December 17, 2018 at 3:29 PM
      Hi Andrew,
      Thank you for the response. I have looked into those, but from my understanding they cannot be used with sending of invoices, etc. Do you have any links you could share that might say otherwise?
      Justin Cooper
    • Zvika Rimalt
      December 18, 2018 at 2:11 AM
      This was discussed just a couple of threads above yours, with the title “Dynamic Subject with Print Management”
      Check out this conversation.
      To help with the suspense though I will tell you there isn’t anything out of the box, and your pain is a common pain (are you listening, Microsoft R&D?)
      https://www.axug.com/communities/community-home/digestviewer/viewthread?GroupId=925&MessageKey=ca76bc57-1034-4c44-933b-b6df20624e55&CommunityKey=af0dadbe-c222-4660-9d1e-a9e3416c837a&tab=digestviewer&ReturnUrl=%2faxug%2fcommunities%2fcommunity-home%2fdigestviewer%3fcommunitykey%3daf0dadbe-c222-4660-9d1e-a9e3416c837a%26tab%3ddigestviewer
      Zvika Rimalt
      Functional Consultant
      Vancouver BC
    • Justin Cooper
      December 18, 2018 at 11:16 AM
      Thank you for sharing that other post, that was very helpful! We are going to evaluate Docentric.
      Thank you,
      Justin Cooper
    DSC Communities replied 6 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Sending docs (invoice, confirmations, etc) via email’ is closed to new replies.
