Same Expense Category/Multiple Main Accounts
Posted by Raheel Rao on January 28, 2020 at 5:24 pm-
Hi All,
I have a scenario where I’m trying to setup expense categories in D365 Finance where there will be two different main accounts for each category depending on two main areas of the business.
Example
Fuel – Area1 – MainAccount 1111
Fuel – Area2 – MainAccount 1112
Meal – Area1 – MainAccount 1122
Meal – Area2 – MainAccount 1123
We already have financial dimensions in use which I’m suggesting however finance in addition to that requires to actually post in separate accounts. Creating two categories for same type of expense will be confusing for end users and will increase chances of errors where they’ll select incorrect category from the area of business which they do not belong to.
Has anyone else run into such a scenario? If yes, how did you solve it?
Any other suggestions with I can keep it simple for the user where all users will see the same list of categories and we somehow based on financial dimension post them to their respective accounts.
I’m keeping the customization option last and trying to see if we can solve this functionally first.
Let me know please.
Raheel
Raheel Rao
Hickory Farms
Chicago, IL
Hi Raheel,
Can you explain how the Area1 and Area2 are used? Are these dimension values or where are they specified? It seems like the Area is the differentiator, but you did not explain anything related to this attribute.
kind regards,AndrƩ Arnaud de Calavon
Product manager, Microsoft MVP – Microsoft Dynamics Business Solutions
Hi Andre, I should have been more clearer. We areĀ using finDims for distinguishing both areas from each other and also have separate accounts for each categories.Ā
After posting this, I started looking into if we can use allocation rule for this purpose and seems like that is something which will help. So lets say, I’ll for now post everything for Fuel expense toĀ MainAccountĀ 1111 for Area1 and then create an allocation rule that picks up any posting done toĀ MainAccountĀ 1111 but for Area2 to create an allocation journal offsetting both accounts to move transactions to MainAccount 1112. Does that makes sense?
Raheel
Raheel Rao
Enterprise Architect
Hickory Farms
IL
Hi Raheel,
Yes, you can indeed try to use allocations, but you can also look from the source. Where is the financial dimension maintained? Is the user selecting this one? Is it related to e.g. a setting on a project or worker? Can you describe how the data flows?
FinDims will come from the userās financial dimensions. So when entering expense/creating expense reports those dimensions will already be present when posting those vouchers. Based on the rules created with source and those particular finDims, weāll move them to correct main accounts for those finDims.
I did a test and seems like a workaround we can use for now.Thanks for your feedback, Andre!
Sent from my iPhone
——Original Message——
Hi Raheel,
Christopher Ho Yee
MemberJanuary 30, 2020 at 12:34 PM
Although a bit more setup, I think another approach would be to use projects.More specifically, you could create cost projects and project groups that represent the different areas. The posting profiles would be setup to direct the expense selected to the corresponding Ledger accounts using the project groups.
The projects themselves could also default the area (and any other related) Financial dimensions.
You will get the transactions directly to the ledger account you desire. You will be able to refer to the original transaction if needed directly.
Christopher Ho Yee
Altius Consulting
Richmond BC
Raheel Rao replied 6 years, 9 months ago 1 Member · 0 Replies -
The discussion ‘Same Expense Category/Multiple Main Accounts’ is closed to new replies.
