Recurring integration – The remote server returned an error: (403) Forbidden
  • Recurring integration – The remote server returned an error: (403) Forbidden
    Posted by Prasanth P on April 28, 2026 at 4:38 am
    we are facing a blocking issue with a recurring integration in D365 F&O production environment. It works fine in all environment but not in production.
    The first import has throw this error: SysIntegrationActivityBatchTask-run. Microsoft.WindowsAzure.Storage.StorageException: The remote server returned an error: (403) Forbidden. —> System.Net.WebException: The remote server returned an error: (403) Forbidden.
    The API is: [environment url]/api/connector/dequeue/{[activit id]}?entity=[entity name]&company=[company]
    Sometimes we are receiving this error. And in 2nd export, The records which was in error batch are not Exporting as expected.
    How can we solve this?
    andrew alwin replied 5 months, 3 weeks ago 3 Members · 2 Replies
  • 2 Replies
  • Hardik Gupta
    April 28, 2026 at 6:32 am
    Down Accepted answer
    Hi @praspras6360gmail-com
    We’ve seen this across multiple production deployments post-deployment. It’s almost always a service principal re-authentication issue; the integration carries cached credentials from lower environments and loses its active token in production.
    Quick Fix (Tested):
    1. Clear & Re-authenticate
    – Data Integration > Edit project > Remove Connection
    – Re-establish connection with fresh OAuth flow in production
    2. Verify Azure AD Permissions
    – Confirm service principal has “Dynamics 365 Finance and Operations” permission
    – Grant admin consent if needed
    3. Reset Batch & Reprocess
    – Check Activity Monitor for failed batches
    – Restart job with fresh authentication
    The 403 error means invalid token/insufficient scope. Re-authenticating in production generates a fresh token and resolves it.
    Let us know if this works or if you need to explore other approaches.
  • andrew alwin
    May 6, 2026 at 8:03 am
    403 in prod but not in other environments is almost always auth/permission or endpoint restriction, not code.
    Things to check:
    AAD App / Service Principal permissions
    Make sure prod has the same API permissions + admin consent as UAT/dev
    Endpoint / URL mismatch
    Double-check the prod base URL and company name in the API call
    IP restrictions / firewall
    Prod endpoints may block requests if coming from different IPs
    Token / auth setup
    Ensure the token is generated for the correct tenant + environment
    Batch service account
    Check if the integration runs under a user/service account that lacks rights in prod
    Also, the fact that retry/export fails suggests the initial failure is not clearing the batch state, so fix the auth first, then reprocess
    In most cases like this, it ends up being missing permission or wrong app registration in production
