PO Stuck
  • PO Stuck
    Posted by DSC Communities on February 6, 2018 at 10:56 am
    • Jessica Murphy
      February 6, 2018 at 10:56 AM
      We’ve got a PO stuck in our system from 2015.Ā  I’ve tried to delete the PO, finish the receiving process, unregister, etc.Ā  I keep getting the error that the item is on hold for transactions in Purchase Order, or that it has a status of Registered.Ā Ā
      How do I close or delete this PO?
      AX2009
      Jessica Murphy
      Master Planner
      Goodwill Industries of Central Indiana
      AX2009 Operations & Maintenance SIG Leader
      Indianapolis IN
    • Genie Engels
      February 6, 2018 at 11:18 AM
      Couple of things to check:
      1. Is the item on hold in the default order settings or site specific orders settings for purchase orders or inventory?
      2. Is the item on quarantine?
      3. What is the status when you look at the inventory transaction?
      a. If it’s registered, you’d need to reverse the registration provided no one has taken the inventory off hand (This can occur since it is registered on hand but financially it’s not received)
      4. Is the period closed in that you can’t complete the receipt?
      5. Is the location on hold / blocked?
      Just a few ideas Jessica!
      Genie Engels
      Solutions Architect
      MCA Connect
      Meridian ID
    • Alex Bailey
      February 7, 2018 at 8:04 AM
      Those are some good pointĀ Genie. I just want to share that we had a similar issue at our company and it was simply because the item was registered. Since it was a ‘special item’ and had been phased out (stopped at all levels), we had to remove the stopped setting, count the item up, and then un register.
      Good Luck!
      Alex Bailey
      ATMC
    • Allen Rupp
      February 7, 2018 at 5:11 PM
      Could you finalize the PO?
      Allen Rupp
      Commercial Purchasing Manager
      Woodland Foods
      Waukegan IL
    • Jessica Murphy
      February 8, 2018 at 11:11 AM
      Good catch Genie!Ā  It was stopped in default order settings.
      Jessica Murphy
      Master Planner
      Indianapolis IN
    • Genie Engels
      February 8, 2018 at 12:23 PM
      Glad you can process now! Ā
      Regards!
      Genie Engels
      Solutions Architect
      MCA Connect
      Meridian ID
The discussion ‘PO Stuck’ is closed to new replies.
