Physical Inventory by Inventory dimension report is incorrect for past dates
  • Physical Inventory by Inventory dimension report is incorrect for past dates
    Posted by Kevin Biggers on June 4, 2025 at 1:09 pm
    When running this report for past dates, the report does not provide accurate results.
    Example
    2/25/2025 there were 10 units in location 5
    3/1/2025 5 units are moved to location 6
    3/5/2025 5 units are sold from location 5
    3/31/2025 inventory is closed, this cleans up the InventSum table.
    4/1/2025 run the Physical inventory by inventory dimension report with a date of 2/28/2025
    The report will look at the current inventory, 5 in location 6. Look back using inventory transactions and see what was in location 6 as of 2/28/25 and return a quantity of 0.
    We have had numerous conversations with MS over this and they maintain this is a limitation of the report and not a bug.
    Has anyone else run into this issue? What was your response from MS?
    Kevin Biggers replied 9 months, 2 weeks ago 1 Member · 0 Replies
