We have picked up a query with regards to the Invoice due dates on the vendor accounts (AP Invoices).
If we navigate to Accounts Payable – Common- Vendors – All vendors Select the relevant vendor and select transactions.
What we are seeing is the Due dates have populated incorrectly.Ā This table reflects as the VendTrans.DueDate.Ā This is a 60 day account whereby the transaction date is the 9th of October 2019 and the due date has been calculated as the 31st of October 2019. Ā If we navigate to Accounts payable – Enquiries – Journals – Invoice journal the date is calculated correctly as the 31st of December 2019.Ā This table reference isĀ VendInvoiceJour. Ā
What could cause the incorrect due dates to populate in the vend trans table. Ā
Your input would be greatly appreciated. Ā
—————————— Erica Burns AX Consultant Omnia Group (PTY) LTD Johannesburg ——————————
I noticed this question was still unanswered. Initially, the due date should be inherited from the invoice. However, it is possible to agree another date with the vendor and then change it on the vendor transaction. This will be used for the payment proposals where the original posted document (invoice) will not be changed. In that case, you can have a situation like you described.
