Parallel GL
  • Parallel GL
    Posted by nazimlalji@hotmail.com on September 2, 2017 at 7:42 pm
    • Najeem JanatAli
      September 2, 2017 at 7:42 PM
      In Dynamics AX 2012, can we maintain parallel GL
      Eg is one on IFRS and other on GAAP
      please advise
      Nazim Lalji
    • Ludwig Reinhard
      September 3, 2017 at 6:20 AM
      ?Hi Nazim Lalji,
      The answer to your question is yes šŸ™‚
      You basically have two options how to realize this:
      Option 1:
      Make use of posting layers, which can be setup at the journal level. Just check out your GL journal setup and identify the posting layer parameter that can be set to something like actual, tax, … An advantage of using posting layers is that you do not need to setup new ledger accounts but post IFRS, local GAAP, … postings on the same account
      Option 2:
      The alternative is using separate classes of accounts for differentiating local GAAP, IFRS, … transactions. This means that you have a separate area in your CoA that hold accounts that are only used let’s say for IFRS postings.
      I personally prefer option 2 more but a lot of people just think the opposite šŸ™‚
      Best regards,
      LudwigĀ
      Ludwig Reinhard
      SYCOR GmbH
      Goettingen
    • Zvika Rimalt
      September 6, 2017 at 3:29 AM
      Another method (alas, a bit cumbersome) method I have seen is consolidating into a consolidation company, and using the “elimination company” functionality to add the additional journals to required for IFRS / GAAP etc.
      Zvika Rimalt
      Functional Consultant
      Vancouver BC Canada
    nazimlalji@hotmail.com replied 9 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Parallel GL’ is closed to new replies.
