Open Purchase Order
  • Open Purchase Order
    Posted by nazimlalji@hotmail.com on August 1, 2018 at 1:32 pm
    • Najeem JanatAli
      August 1, 2018 at 1:32 PM
      HiĀ
      Please can some shareĀ  knowledge how to close the Open PO or balance or PO
      thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • Andrew Lencsak
      August 1, 2018 at 4:42 PM
      Hi Nazim, there are a couple options depending on your exact scenario.
      You can cancel the delivery remainder of the PO line(s) if the open quantity is no longer needed. This can be done from the PO Line > Update line dropdown> Delivery remainder option. You can then use the Cancel qty button to remove the open quantity or just reduce the Purchase quantity if you only need to cancel part of the quantity rather than the entire open amount.
      There is also a checkbox called “Close” which you can tick when you post a Purchase Order Product Receipt for a quantity received that will cancel the remaining open quantity on the line.
      Andrew Lencsak
      Senior Application Consultant/Solution Architect
      eBECS Limited
      Atlanta GA
    nazimlalji@hotmail.com replied 7 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Open Purchase Order’ is closed to new replies.
