Obsolete Items by Product Variant
  • Obsolete Items by Product Variant
    Posted by Unknown Member on August 2, 2019 at 3:32 pm
    • Carey Ryerson
      August 2, 2019 at 3:32 PM
      We need to mark items as obsolete by product variant (in my case, color).Ā  “Obsolete” means that a sales order cannot be placed against the item in the obsolete color and planning will ignore the obsolete color.Ā  Is there a way to accomplish this? We are in D365 10.0.3. #D365, #FinanceandOperations????
      Carey Ryerson
      Magpul
      Cheyenne, WY
    • MICHAEL MILLS
      August 5, 2019 at 7:07 AM
      What version are you on?
      Michael Mills
      AX D365 Enterprise Consultant Operations
      Blue Horseshoe Solutions
      Carmel, IN
    • MICHAEL MILLS
      August 5, 2019 at 7:08 AM
      What version of AX are you on?
      Michael Mills
      Carmel, IN
    • Andrew Lencsak
      August 5, 2019 at 4:07 PM
      Hi Carey,Ā
      Ā you’d have to do two things:
      1) Have an obsolete product lifecycle state with the checkbox “Is active for planning” disabled and assign it to all the Released product variants that you no longer sell.
      2) Under Default order settings, check the “Stopped” flag under each tab either for each variant combination or at the 0 level to apply to all configurations.
      Drew
      Andrew Lencsak
      Solution Architect
      DXC
      GA
    • Carey Ryerson
      August 7, 2019 at 11:13 AM
      This is perfect.Ā  Thank you!
      Carey Ryerson
      Magpul
      Austin TX
    • Greg Pope
      August 8, 2019 at 7:29 AM
      Hi Andrew,
      Is this same functionality available in AX 2012 R3?
      Greg
      Greg Pope
      Master Scheduler
      Paul Reed Smith Guitars
      Stevensville MD
    • Andrew Lencsak
      August 8, 2019 at 12:29 PM
      Hi Greg,
      I was searching for release notes to see if this functionality was backported to AX2012 R3 on a later CU but was having trouble confirming.Ā  I do not believe it is available but if anyone is 100% sure, please comment here šŸ™‚
      Andrew Lencsak
      Solution Architect
      DXC
      GA
    • Sarah Gabriel
      August 9, 2019 at 11:16 AM
      Hi Greg,Ā
      AX 2012 R3 does not have this functionality. You can only stop the product masters and not the released variants individually. We looked into a customization but decided to hold off because it is standard in D365FO.
      Sarah Gabriel
      Operations Business Analyst
      Kai USA Ltd
      Tualatin OR
    • Greg Pope
      August 12, 2019 at 7:07 AM
      Thanks, Sarah. Thanks, Andrew. I’ll check into the backporting option. That would be a great solution for us if its available.
      Greg Pope
      Master Scheduler
      Stevensville MD
    Unknown Member replied 6 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Obsolete Items by Product Variant’ is closed to new replies.
