We load all of our large journals this way but I am currently in discussion with Microsoft (via a support ticket) because it takes way longer than I think it should when we try to import journals that are 10K-20K lines. It is taking 4+ hours for a 19K line journal, for example. The response I received from MS support initially was that we should break down the imports into smaller batches but I pushed back that this was not a solution, rather it was a workaround and not at all acceptable.Ā
If anyone has a different experience with this functionality, please let me know. While 20K lines is a lot of data, my expectation is that Dynamics should be able to handle in minutes, not hours.
—————————— Karl Arensdorf Corporate Controller Mansfield Oil Company Gainesville GA —————————— ——————————————-
Our experience varied somewhat but we’ve definitely loaded in 10k to 20k lines in under an hour. Anecdotally, any file that had a single error line (some of the data was invalid) took significantly longer to load in than a file with no errors. The entity being loaded into also affected that as the more validations required on the data the longer it took for the system to upload.
