Master Scheduling batch job does not create planned purchase orders
  • Master Scheduling batch job does not create planned purchase orders
    Posted by DSC Communities on January 11, 2017 at 7:39 am
    • Archive User
      January 11, 2017 at 7:39 AM
      AX2012 R3 CU11 – WHS enabled
      We are experiencing an issue where master schedulng is not generating planned purchase orders for formula items during the overnight batch job in this specific situation.
      Production order is created, estimated, and scheduled.
      We need to replace an item in the production order formula so we reset the status of the production order to created and replace the existing item by reducing the quantity to zero, add the new item, and then re-estimate and re-schedule.
      We have found that, after this process, when master scheduling runs overnight it is not generating new planned purchase orders for the new item. Even if you add a min coverage setting it still does not create any planned purchase orders.
      However, if you run net requirements on the new item, planned purchase orders are generated as expected.
      We have reviewed master planning parms, coverage group settings, master plan settings, and have recalculated BOM levels to no avail.
      Any ideas would be greatly appreciated.
      Thanks.
      Dan Collins
      Agility Business Solutions
      Cleveland OH
    • Andrew Lencsak
      January 11, 2017 at 10:24 AM
      Hi Dan,
      Not entirely sure if it’s the same issue but there was a hotfix for CU11 relating to BOM levels. Maybe something you need?
      KB3178134 “Recalculate BOM levels does not correct BOM levels for raw materials in certain ProductionBatch order scenarios causing MRP Explosion problems “
      A new table, ReqItemLevel, was introduced to be used for planning purposes as there were instances where the BOMlevel could not be used to properly represent the structure for MRP purposes and for BOM purposes.
      One of my client’s recently had a similar issue with this, if I remember correctly, running from Net requirements is a bit different in the way it hits that new table as compared to running from the Periodic job.
      Andrew Lencsak
      Senior Application Consultant
      eBECS
      Atlanta GA
    • Archive User
      January 11, 2017 at 1:35 PM
      Thanks Andrew.
      Dan Collins
      Cleveland OH
    • Archive User
      January 13, 2017 at 2:49 PM
      As a follow up – we have seen that new items are not being added tot he reqitemlevel table.
      Dan Collins
      Cleveland OH
    • Kelly (Kane) Gustafson
      January 11, 2017 at 8:12 AM
      Hi Dan,
      Do you have a batch job to Delete plans prior to running your Master scheduling batch jobs?
      Kelly Kane
      Information Systems Specialist
      Algood Food Company
      Louisville KY
      AXUG Kentucky Chapter Leader
      http://www.axug.com/lexington
      http://www.axsoup.com
    • Archive User
      January 11, 2017 at 1:51 PM
      Thanks Kelly.
      Dan Collins
      Cleveland OH
    DSC Communities replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Master Scheduling batch job does not create planned purchase orders’ is closed to new replies.
