Management reporter Totals row is blank
  • Management reporter Totals row is blank
    Posted by nazimlalji@hotmail.com on May 26, 2019 at 4:29 pm
    • Najeem JanatAli
      May 26, 2019 at 4:29 PM
      HI All
      Started with a simple report: Trial Balance: containing 50000 rows. some how its not showing the last line which is TOTAL and the amount, although it shows single and double underlines
      any suggestion
      Thanks and kind regards
    • Sharon Nolan
      May 28, 2019 at 11:13 AM
      ?Without seeing yourĀ Row Definition (at least the last couple of lines) or your Column Definition, it is hard to troubleshoot.
      When you have the report open in MR, on the Settings tab, is the Other Formatting option of Display blanks for zero amounts marked or unmarked?
      Is the total line simply not showing or is it the fact that the Trial Balance is equal to (in total) $0.00?
      Thank you
      Sharon Nolan
      Senior ERP Business Analyst
      Bay Industries Inc.
      Green Bay WI
    • Najeem JanatAli
      May 29, 2019 at 11:42 PM
      Hi Sharon
      Trial balance report : Columns : Account #, description. balance. Last line where its TOTAL that line is blank only underlines are there. Where as using same Row definition and changed the column to reflect movement, this report reflect totals
      Here are the setting screen shot attached
    • Noah Moseley
      June 4, 2019 at 9:37 AM
      Hi Nazim.
      Odds are you have the checkbox unchecked on the Report Definition Settings tab that says “Display Rows with No Amounts”. Check this box and in your Row Definition, use X0 as a Print Control on every row with an account reference. Do not use X0 on the Total Row.Ā
      Alternatively, I probably would not have 50000 rows on my Row Definition. I would use one row with a range of account numbers (i.e. 100000:999999) and run the report with account-level detail to drilldown to the details. Less maintenance that way.
      See you in Orlando? I am teaching Management Reporter training classes on October 14th and 15th the two days prior to Summit. https://na.usergroupsummit.com
      Noah Moseley
      Senior Partner/Consultant
      MSX Group
      Pensacola FL
    nazimlalji@hotmail.com replied 6 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Management reporter Totals row is blank’ is closed to new replies.
