We are on AX 2012 R3, Management reportor specially for where blockĀ “Tree” reporting is set up its time out or running like half an hour to produce a report
Last month same report was fine and was not taking that long to run
Increase RAM memory on server (see install prereqs pdf file attached)
Sometimes split the three MgtRpt components onto separate servers (process service, application service, data mart)
You may change timeout settings (see install config pdf file attached) in config files on server
Shy away from transaction detail with many monthlyĀ periodic columns unless truly needed
Be on latest MR 2012 CU16 release
I would be glad to complimentary look at report layout andĀ server config via GoToMeeting
Hope to see you and others at the regular Mgt Reporter trainings we do regularly for AXUG so look to their Academy Learning line orĀ email anytime for questions/tips
3rd option :Ā You may change timeout settings, helped to fix the issue. Now reports runs in seconds
Thank you so much for always being here to assist with MR
Please when are you planning to conduct MR technical session like Data Mart refresh and MR versions knowledge based training, how to upgrade to to CPU16
Also want to share that we are on CU8Ā 2.1.8991.0 which doesnt support AX 2012 R3 Ledger but it supported
