Is there a way to automatically clear FX differences each month?
  • Is there a way to automatically clear FX differences each month?
    Posted by Unknown Member on March 23, 2017 at 6:31 pm
    • Sherry Moran
      March 23, 2017 at 6:31 PM
      We found that when a foreign currency PO is received it hits the 201500 GL account using one exchange rate, when that PO is vouchered it offsets the same GL account using a different exchange rate thereby leaving a foreign exchange difference in the account.  Is there a way to clear these transactions out or is there a setup on the account which may handle this?
      Sherry
      Sherry Moran
      SR Business Systems Analyst
      Key Technology, Inc
      Walla Walla WA
    • Napoleon Cordoviz
      March 24, 2017 at 9:34 AM
      There is a periodic foreign currency revaluation process that you can run in the GL, AP and AR which I believe should handle this.
      Napoleon Cordoviz
      Sr. Business Analyst
      Universal Weather and Aviation, Inc
    • Heather Roskewich
      March 24, 2017 at 11:18 AM
      Hi Sherry,
      Which version of AX are you using? We had similar issues with AX2012 R2 but R3 cleaned up the double postings on inbound product receipts so it’s better now. Without knowing your GL structure, I’m going to assume that the GL account you mention is a balance sheet account and these amounts are getting stuck on your balance sheet. There is a white paper that I found helpful and, with some adjustments, we’ve solved most of our issues with a partial adoption of their recommendations. We do still have problems with FX variances on negative PO lines (vendor returns) so it’s not a perfect solution but I know what to look for now and manage it accordingly.
      Search for: Microsoft Dynamics® AX 2012 R3 Accounting for stocked items on product receipts and vendor invoices
      There used to be a white paper for older versions of AX but I can’t seem to find it now.
      Good luck,
      Heather
      Heather Roskewich
      Somagen Diagnostics Inc.
      Edmonton AB
    • Sherry Moran
      March 27, 2017 at 10:20 AM
      Napolean – I believe we’ve tried running that but I’ll run again to be sure.
      Heather – we’re on AX2012 R2 CU 7, I’ll look for the white paper too.  We’ve debated going to R3, this may be another tick in the yes column if we can’t resolved in R2 in a somewhat automated fashion.  Thank you for the tip.
      Sherry
      Sherry Moran
      Key Technology, Inc
      Walla Walla WA
    • Heather Roskewich
      March 28, 2017 at 2:02 PM
      Hi Sherry,
      I found the old white paper (attached) – it instructs you to push the variances to the P&L. I’ve studied the postings behind this closely and did consult with a finance consultant who told me that Microsoft suggest that this works appropriately. The variance appears when an invoice is posted to the stock receipt on a different day or period than the stock receipt and when the exchange rate has changed. It seems ‘off’ to me but I’ve found no other solution. R3 will definitely help, at least for inbound stock receipts. The FX revaluation didn’t work for us.
      Cheers.
      Heather Roskewich
      Edmonton AB
    Unknown Member replied 8 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Is there a way to automatically clear FX differences each month?’ is closed to new replies.
