Template: Invoice entry that you will use on a regular basis and you will use the same Ledger and vendor each time. Description, date and amount should change.
And it’s not a “periodic entry”.
—————————— Richard Malouin CPA, CGA PSP Investments —————————— ——————————————-
Thanks for the clarification. I’m aware of the voucher template functionality, but got confused. There is actually one option to delete the voucher templates. When you open theĀ Select voucher template form from the sub menu as shared above by you, you are able to mainly select templates. If you select a certain template (upper part of the form), you can use the key combinationĀ ALT+F9 orĀ ALT+DEL to delete a template.
