Import Demand Forecast entity
  • Import Demand Forecast entity
    Posted by MIGUEL ROMMERS on August 2, 2024 at 6:00 pm
    It is possible to import the Demand forecast entries entity in Dynamics F&0 without having to fill out the ForecastEntryNumber column in Excel and that Dynamics can create demand forecast and automatically fill out the field and update the numerical sequence ?
    Thanks for the answer
    MIGUEL ROMMERS replied 1 year, 6 months ago 2 Members · 2 Replies
  • 2 Replies
  • Drew Lencsak
    August 23, 2024 at 10:18 am
    Down Accepted answer
    Are you using DMF or attempting to publish updates through the Data entity using Open in Excel? In the past, I have often imported forecasting using the Open in Excel feature and the Default forecast sequence number can be populated automatically. I cannot remember 100% when using DMF and importing a file, but have you tried importing with the column left off and out of your mapping and have D365 attempt to create it during import?
  • MIGUEL ROMMERS
    September 6, 2024 at 3:42 pm
    Hi Drew,
    I use the excel template without the column and import with DMF and it works correctly.
    Thank you
