How to Remove Item From Shipment After Pick in Advanced Warehousing
  • How to Remove Item From Shipment After Pick in Advanced Warehousing
    Posted by DSC Communities on December 13, 2018 at 1:23 pm
    • Alison Wright
      December 13, 2018 at 1:23 PM
      We have been live with AX 2012 R3 for several months now and still do not have a definitive process for handling the situation where a sales order is released to the warehouse, the picking work completed, and then someone asks to have one or more items canceled off the order before (or after) it has been packed.
      I have tried using the “Reduce picked quantity” button on the load without success.
      Any suggestions are greatly appreciated!
      Alison
      Alison Wright
      IT/Project Manager
      The Dodge Company
      Billerica MA
    • Robert Harriman
      December 14, 2018 at 8:04 AM
      Hello Alison,
      You may have missed a step during reduce picked quantity. After you reduce the picked quantity, expand the “Shipment” fast tab within the shipment details. If you still see shipment details, click the delete button from the ribbon at the top.Ā
      This usually works for us.Ā
      Rob
      Robert Harriman
      The Eastwood Company
      Pottstown PA
    • Alison Wright
      December 14, 2018 at 10:32 AM
      Hi Rob,
      Thanks for the reply.Ā  Looking at your response, I think my problem is that I can’t get past the “reduce picked quantity” step.Ā  After I select a location and an amount to reduce and click “OK” I get an infolog error that the “Work failed to cancel”.Ā  A setup issue maybe?
      Alison
      Alison Wright
      IT/Project Manager
      The Dodge Company
      Billerica MA
    • Robert Harriman
      December 14, 2018 at 11:02 AM
      Hi Alison,
      I copied your scenario up to packing. I then went back to the sales order and placed it on hold. I then tried to reduce the picked quantity and it gave an error, not the same as yours but it’s the only time I can get it to error. Are you placing your orders on hold? Maybe talk to your Ax Developers too, could be a setup issue as you say?
      Rob
      Robert Harriman
      Pottstown PA
    • Tony Zeigler
      December 14, 2018 at 1:57 PM
      ?What would you tell them if the item had already shipped?
      I ask, because the two situations are very similar – and just telling the customer it’s too late to change their mind might be a better answer…or to send it back and let it go thru the returns process…
      (Usually if it’s been picked, it’s either packed & sitting on the dock waiting for pickup, or will be very shortly….)
      Tony
      Tony Zeigler
      Senior Consultant
      Strategic Solutions NW, LLC
      Beaverton OR
    • Robert Harriman
      December 14, 2018 at 3:06 PM
      I absolutely agree with you Tony however, there are times where you need to make these adjustments, sometimes it’s way more cost effective to make the cancellation. It all depends on the circumstance.
      Robert Harriman
      Pottstown PA
    • Andrew Lencsak
      December 17, 2018 at 3:28 PM
      Hi Alison,
      The reduce picked quantity button can be used if the line being “reduced” has already been fully processed on the Work ID. When you click the button to remove a line from the load, you should be prompted with another screen where you have to specify the quantity to be unpicked and the location you are moving the inventory to. If you just click the button then OK, nothing will occur and the item will not be unpicked or moved.
      Drew
      Andrew Lencsak
      Senior Application Consultant/Solution Architect
      eBECS Limited
      Atlanta GA
    DSC Communities replied 7 years, 3 months ago 1 Member · 0 Replies
The discussion ‘How to Remove Item From Shipment After Pick in Advanced Warehousing’ is closed to new replies.
