Generate a view column based on column data
  • Generate a view column based on column data
    Posted by DSC Communities on January 19, 2017 at 1:17 pm
    • Andy Norton
      January 19, 2017 at 1:17 PM
      I’ve created a view that uses the InvoiceAmountMST column.
      I’d like another column to be a string “Invoice” if this value is positive, if this value is negative “Credit”.
      I’ve taken a look at Computed View Columns in AX, although I’m not 100% sure this is the right method?
      A first attempt below, I’m stuck at how to get a numeric value from the dictView and then return a string after checking for negative figures (if this is indeed the right way to go)
      public static server str getInvoiceType()
          #define.CompView(GBCustInvoiceJourView)
          #define.CompDS(CustInvoiceJour_1)
          #define.InvoiceAmountMSTCol(InvoiceAmountMST)
          str invoiceAmount;
          DictView dictView;
          dictView = new DictView(tableNum(GBCustInvoiceJourView));
          invoiceAmount = dictView.computedColumnString(identifierStr(CustInvoiceJour_1),
              fieldStr(GBCustInvoiceJourView, InvoiceAmountMST),
              FieldNameGenerationMode::FieldList,
              true);
      AX 2012 R2
    • Colby Gallagher
      January 19, 2017 at 9:09 PM
      Yup, computed columns on a view can do this just fine.  Try this:
      private static server str getInvoiceType()
          TableName ViewName = identifierstr(GBCustInvoiceJourView);
          str CustInvJour = identifierstr(“CustInvoiceJour_1”);
          str invoiceAmount, sReturn;
      invoiceAmount = sysComputedColumn::ReturnField(ViewName, CustInvJour, fieldStr(CustInvoiceJour, InvoiceAmountMST));
      sReturn = “Select Case when ” +invoiceAmount + “>0 THEN ‘Invoice’ Else ‘Credit’ END “;
          return sReturn;
      Colby Gallagher
      Agility Business Solutions
      Brecksville OH
    • Andy Norton
      January 29, 2017 at 10:58 AM
      This worked perfectly, thanks!
      AX 2012 R2
    DSC Communities replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Generate a view column based on column data’ is closed to new replies.
