FX Revaluation
  • FX Revaluation
    Posted by DSC Communities on January 9, 2020 at 2:04 am
    • Christopher Ho Yee
      January 9, 2020 at 2:04 AM
      Hoping to get some out of box assistance here.
      I have a scenario where there is a Consolidation company that consolidates multiple subsidiaries with differing accounting currencies, but the same reporting currency. The company has a need to calculate a FX revaluation on ALL Balance sheet accounts in the Consolidation company, but ONLY CERTAIN (i.e. monetary) accounts in their subsidiaries.
      All the companies have been setup with the same shared Chart of Accounts.
      To achieve this requirement, we have enabled Foreign Currency Revaluation across all Balance Sheet accounts which satisfies the requirements for the Consolidation company. However, in doing so, this opens up the possibility for non-monetary accounts to be revalued at the subsidiary level when it is not intended. To compensate, we manually specify the range of monetary accounts in which the revaluation will apply during the FX revaluation (i.e. we exclude the non-monetary accounts from the revaluation).
      This is less than ideal process as the list of accounts in each of the subsidiaries has to be manually maintained whenever new accounts are setup.
      Has anyone encountered this scenario and tackled it in a more effective manner?
      Appreciate any insights!
      Cheers,
      Christopher Ho Yee
      Altius Consulting
      Richmond BC
    • Kaare Boraas
      January 10, 2020 at 10:16 AM
      Hello Christopher.Ā  Consolidation used to be my jam, but it’s been a long time.Ā  Below is a link to a blog post a wrote a number of years ago and recently republished on the D365 forum.Ā  Not sure if it helps with your question, but might be worth a peek.
      https://www.axug.com/axug/blogs/kaare-boraas/2019/10/24/d365fo-how-to-consolidate-a-foreign-subsidiary
      Kaare Boraas
      Relationship Manager
      PCL Constructors Inc.
      Edmonton AB
    • Brad Bertchie
      January 14, 2020 at 12:01 PM
      Christopher;
      When using a shared chart of accounts – that is how you handle this situation.
      Usually makes most accountants scream at first – but once you set up the query in FX reval for the subs – it becomes very manageable.
      Brad Bertchie
      Western Computer
      Oxnard CA
      January 14, 2020 at 12:44 PM
      Thanks for the confirmation Brad!
      Yes, we have a bunch of annoyed accountants. We’re looking at developing an extension to filter by a new field that will group the monetary accounts that are subject to FX revaluation in the subsidiaries.
      Cheers,
      Christopher Ho Yee
      Altius Consulting
      Richmond BC
The discussion ‘FX Revaluation’ is closed to new replies.
