#Fixed Asset# Depreciation
  • #Fixed Asset# Depreciation
    Posted by DSC Communities on August 26, 2019 at 5:27 pm
    • Sudhir Mahajran
      August 26, 2019 at 5:27 PM
      ?Hi All,
      accidently, we have set up minimum depreciation amount in reporting currency as $10 in our D365. Do you know if we can change this.
      Min depreciation amount in reporitng currency
      Also, when importing FA acquisition or depreciation journal, we have to mention exchange rate as 1. we are only transacting in USD. accounting currency and reporting currecny is USD for our legal entity.
      Earliest responce will be highly appreciated.
      thank you
      sudhir
      [Sudhir] [Maharjan] [srmaharjan@hotmail.com]
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Deb Salyer
      August 27, 2019 at 8:03 AM
      Go to fixed asset parameters and you will see the minimum depreciation amount.Ā  For importing when you have dollar values you need to specify the currency in the template you are importing from.Ā  You should not have to import the exchange rate amount.Ā  I would double check your currency exchange setups in GL.
      Deb Salyer
      DS Erp Inc
      Sarasota FL
      941-351-2990
      deb@dserpinc.com
    • Sudhir Mahajran
      August 27, 2019 at 8:50 AM
      ?Hi Deb,
      thank you for your responce. Do you know how we can delete it. I see the minimum depreciation to be 10 and need to get rid of it. Attached screenshot for your refrence.
      thank you.
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Deb Salyer
      August 27, 2019 at 9:30 AM
      You should just be able to change it what do you want it to be
      Deb Salyer MCITP
      941-351-2990
      ——Original Message——
      ?Hi Deb,
      thank you.
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Sudhir Mahajran
      August 27, 2019 at 1:22 PM
      Trying it to make it 0. it is locked down. Have you changed it in the past.?
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Deb Salyer
      August 27, 2019 at 1:59 PM
      Yes I’m able to change mine
      Deb Salyer MCITP
      941-351-2990
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Sudhir Mahajran
      August 27, 2019 at 2:59 PM
      can you put 10 and save and then try to change it to 0.
      Mine is locked down.?
      [AX Consultant]
      [SAGlobal]
      Lawrenceville NJ
    • Zvika Rimalt
      August 28, 2019 at 2:39 AM
      It’s also locked on all my instances in D365
      Zvika Rimalt
      Functional Consultant
      Vancouver BC
    DSC Communities replied 6 years ago 1 Member · 0 Replies
The discussion ‘#Fixed Asset# Depreciation’ is closed to new replies.
