Although fiscal period Jun 2018 is open and its for ALL module,Ā
However while running the roll forward system is keep giving error message:
“The fiscal year that ends with the date 6/30/2018 is already closed”
Checked the fiscal year end Jun 2018 its open, Created and open Year 2019
please advise
thanks and kind regards
—————————— Nazim Lalji Dynamics AX Analyst
Ludwig Reinhard
August 3, 2018 at 12:44 AM
Hi, What do you mean exactly when saying “running the roll forward” What process did you start? Did you simply try entering a new transaction in the new year? Would be great if you could clarify. Many thanks and best regards, Ludwig
—————————— Ludwig Reinhard Sycor Goettingen —————————— ——————————————-
Steve Latta
August 3, 2018 at 11:45 AM
?Check your settings in General Ledger>General Ledger Parameters>Ledger>Fiscal Year Close and make sure you didn’t have “Set fiscal year status to closed” checked. If it was, then you may have closed the year when you transferred Closing>Opening balances.
—————————— Steve Latta Accountant Ortec, Inc. Easley SC —————————— ——————————————-
That’s not check markedĀ “Set fiscal year status to close” and we never choose the status closed, its open or on hold, in same setting able to run Roll forward for 2017 but not for 2018
Jun 30, 2018 is year end. carry forward Balance sheet transaction to next year and retained earnings which contained retained earnings of prior years and Profit and loss of last year
Path: GL > Periodic > Fiscal Year close > Opening transactions — opens up a window: Error : infolog:Ā The fiscal year that ends with the date 6/30/2018 is already closed.
Although Jun 30, 2018 is open, set up 2019 and July is open, dont understand where the issue is
Please feel free to let me know any question
Murali Dorai
August 6, 2018 at 6:41 AM
Hello Nazim,
Try clearing the usage data in user options and try to run the year end close and let me know if it worked.
Kind regards, Murali Dorai
—————————— Murali Dorai SIS (Strategic Industry Solutions) Duluth GA —————————— ——————————————-
