Edit Procurement category in Purchase requisition form in AX 2012 R3
  • Edit Procurement category in Purchase requisition form in AX 2012 R3
    Posted by nazimlalji@hotmail.com on March 17, 2020 at 8:12 pm
    • Najeem JanatAli
      March 17, 2020 at 8:12 PM
      Hi All
      Any one have any suggestion how to make procurement category field allow to edit,
      When PR is rejected by approval as to change the procurement category, requester is unable to edit and change, requester has to reenter the line again
      please advise
      Thanks and kind regards
    • MICHAEL MILLS
      March 18, 2020 at 9:28 AM
      Hi Najeem,
      I do not think their is a way to modify the line category once it has been submitted.
      Michael Mills
      AX D365 Sr. Enterprise Consultant Operations
      Blue Horseshoe Solutions
      Carmel, IN
    • Pirmin Bercher
      March 18, 2020 at 12:35 PM
      Hi,Ā
      do you work with itemnumbers ?
      I just checked, if working with items for the requistion, the categroy is pulled from the item.
      Even upon creation of requistion you can’t change. If you go to the table in AOT you can .. so must be somthinh g in the form.
      Guess a programmer can help you
      Regards
      Pirmin
      Pirmin Bercher
      Head of Business – IT Alignment
      CARBOGEN AMCIS
      Aarau
    • Najeem JanatAli
      March 18, 2020 at 2:18 PM
      Hi Pirmin
      Nope notĀ  using Item numbers, using procurement category under PIM module linked with posting under IM module
      Correct you are right need some touch up in AOT, looking for some tech person feed back in which area to make it editable
      thanks and kind regards——————————————-
    nazimlalji@hotmail.com replied 5 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Edit Procurement category in Purchase requisition form in AX 2012 R3’ is closed to new replies.
