Dynamics AX 2012 R3 client crashes after opening.
  • Dynamics AX 2012 R3 client crashes after opening.
    Posted by DSC Communities on April 15, 2017 at 4:51 pm
    • Uzair Shah
      April 15, 2017 at 4:51 PM
      Hi guys,
      I need your help urgently. Dynamics AX 2012 R3 client crashes after opening. I can see Session ID on the top of the screen but suddenly AX client sessions crashes. There is no event log to find out what exactly is the issue. I deleted the records from SysClientSessionsTables and SysServerSessionsTables but it didn’t work for me. Kindly help me.
      Uzair
      Uzair Shah
      Alfazance Consulting
    • Michael Costello
      April 15, 2017 at 9:25 PM
      Is this just happening for one user (client) or all?
      – If just one then I suggest resetting the usage data.
      Did your AOS crash too?
      You should only clear all records from the SysServerSessions & SysClientSessions table when all AOS(s) are shut down.Ā
      Please make sure thatĀ  you don’t have a filter on either the application or System event logs.Ā  Typically there will be something there.Ā  Please also look at the info messages right before the crash as these sometimes can provide some information.
      Michael Costello
      McWane, Inc.
    • Craig Leska
      April 17, 2017 at 9:51 AM
      I concur with MichaelĀ on resetting the usage data, you can also try clearing out the AUC files in the
      %userprofile%/appdata directory if resetting the usage profile does not work.
      Craig Leska
      Logan Consulting
      Chicago IL
    • Tony Zeigler
      April 17, 2017 at 11:02 AM
      If it’s occurring for a particular user you should also consider erasing their personalizations using an admin account.
      Tony Zeigler
      Strategic Solutions NW, LLC
      Beaverton OR
    • Paul Martin
      April 17, 2017 at 6:42 PM
      one other thing is to delete their visual assemblies under app data MicrosoftĀ  Dynamics AX on their user profile
      Paul Martin
      Expert ERP Analyst
      TempurSealy Inc.
      Trinity NC
The discussion ‘Dynamics AX 2012 R3 client crashes after opening.’ is closed to new replies.
