DMF – D365 F & O
  • DMF – D365 F & O
    Posted by DSC Communities on September 13, 2019 at 5:04 pm
    • Srikanth Konda
      September 13, 2019 at 5:04 PM
      I want to import the purchase order header and lines information into D365FO system for Insert/Update and am aware that there is a standard composite entity which does that, but with limitation of only XML file types. I want to import data from Excel files.
      I tried to create a custom data entity with the PurchTable and PurchLine tables. As usual, the export works smoothly but the import doesn’t for obvious reasons. The system validates the purchId from PurchLine table and will not find a match and throws an error.Ā
      Can someone help me what methods I can use for following.
      For, new PO header and lines I want to insert data into the header first and then attempt to insert in the line.
      Srikanth
      Srikanth Konda
    • Chaitanya Golla
      September 15, 2019 at 10:54 PM
      You can implement the numbersequence code either in method initValue (or) post-event handler of method mapDataSourceToEntity of your custom entity. While importing the data specify the value for PurchId as 1,2(on header) and so on(also on the purchase order lines accordingly).
      Sample code:
      NumberSeqRecordFieldHandler::enableNumberSequenceControlForField(
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  this, fieldNum(customEntity, PurchId), PurchParameters::numRefPurchId());
      Chaitanya Golla
      Lead Architect
    • vishal Dhawgaye
      September 25, 2019 at 5:16 PM
      Hi Srikanth,
      If you are bringing purchase orders from legacy system and If your file already includes ‘purchId’, then your can make your number sequence as ‘manual’. you can do that from number sequence setup and entity will create purchase order with Id in file. If you planning to create your own purchId and want to populate it from header. you have to create composite entity, refer ‘SalesOrderEntity’ for the same.Ā
      vishal Dhawgaye
      Hitachi Solutions America, Ltd.
    • Glenn Linaa
      September 26, 2019 at 2:29 AM
      I am not sure this is what you want, but during the import you can go to the map for the header entity and change the purchaseordernumber to auto. This lets the import auto generate the PO number and I think it also align the lines to the new number.
      Glenn Linaa
      Tasklet Factory Mobile WMS
      aalborg, Denmark
    DSC Communities replied 6 years, 6 months ago 1 Member · 0 Replies
The discussion ‘DMF – D365 F & O’ is closed to new replies.
