Dates must be in same fiscal year
  • Dates must be in same fiscal year
    Posted by nazimlalji@hotmail.com on June 4, 2019 at 12:28 pm
    • Najeem JanatAli
      June 4, 2019 at 12:28 PM
      Hi All
      I am unable to run Trial balance, receiving following error message
      From date is in fiscal year 2019. To date is in fiscal year 2019. Dates must be in same fiscal year
      any suggestion
      thanks and kind regards
    • Mark Bailey
      June 5, 2019 at 5:07 AM
      Hi Nazim,
      That message is thrown when the from date and the to date you are trying to view the TB by are in different fiscal years.
      E.g.Ā  Ā Fiscal year isĀ  01/04/19 – 31/12/19
      TB
      FromĀ  = 01/02/19
      ToĀ  Ā  Ā  Ā = 31/05/19
      AX/D365 will throw an error message as you are trying to report on 2 fiscal years.
      TB
      From = 01/02/19
      ToĀ  Ā  Ā =Ā  31/05/19
      AX/D365 will not throw an error as the dates are in the same financial/fiscal year
      Have a look at the periods in the financial calendar in the GL -> Set up area and try to report on dates within a calendar year.
      Kind Regards
      Mark
      Mark Bailey
      Application Consultant
      Annata
      Portsmouth
    • Stacy Black
      June 5, 2019 at 8:12 AM
      Nazim,
      The error is related to the calendar chosen when the legal entity was setup.Ā  If the legal entity had a Gregorian calendar setup in the Ledger, then the periods that could be requested in the Parameters of the Trial balance would be from 1/1 through 12/31.Ā  However, if you are trying to report on the Gregorian calendar and your legal entity has a fiscal year from 4/1 through 3/31 you will not be able to get this from native AX, you would be better off to use Management reporter and modify the base periods/years to report the time frame you are looking for.
      Hope this helps,
      Stacy Black
      Senior Application Consultant
      MCA Connect
      Denver CO
    nazimlalji@hotmail.com replied 6 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Dates must be in same fiscal year’ is closed to new replies.
