D365 F&O Inventory Cost and Transfer Orders
  • D365 F&O Inventory Cost and Transfer Orders
    Posted by DSC Communities on April 16, 2020 at 4:22 pm
    • Anilda Pena
      April 16, 2020 at 4:22 PM
      We set up a purchase automatic charge that is added to the inventory cost at the time of product receipt which works as expected.Ā  However, we found that when we do an inventory transfer from our main warehouse to our other location using a transfer order, the inventory cost for the items being transferred does not include the automatic charge.Ā  Ā  We use WMS at our main warehouse and we use moving average costing method.Ā
      Example:
      Item 12345
      Quantity 2Ā
      Purchase price $??32.29/unitĀ  = Net amount 32.29*2 = 64.58
      Our charge $60.00/unitĀ  = total charge 60*2 =120.00
      Total amount on PO (inventory cost)- 184.58
      We transfer qty 1Ā
      Inventory cost at the transfer warehouse shows $32.29Ā  (we expect inventory cost at $92.29 ($32.29+60.00)
      When we sell the item we show a larger margin because the inventory cost does not include the charge.Ā Ā
      Sales order
      Ā  Sales price $126.26 inventory cost $32.29 = Est profit $93.97. In actuality, it should be $33.97.Ā
      Does anyone have any thought on why the inventory cost at the time of sales order does not pick up the correct inventory cost?Ā
      Thank you,Ā
      Anilda Pena
      Anilda Pena
      Sr. IT Business Analyst
      Omniparts Automotive
      Franklin TN
    • Arush Kuthiala
      April 17, 2020 at 8:14 AM
      Hi Anilda
      How are you adding the charge, is it using standard charges on the PO? Also what does the cost say if you were to sell out of the first warehouse?
      Arush Kuthiala
      Western Computer
      Toronto ON
    • Anilda Pena
      April 17, 2020 at 9:46 AM
      HiĀ Arush,
      Yes we have setup automatic charges which gets added to the PO when criteria is met.Ā  Ā The cost shows $92.29 when I create sales order out of the first warehouse.Ā  Perhaps the balance $60.00 will be recalculated when we do inventory close and recalculation.Ā Ā
      Thank you,
      AnildaĀ
      Anilda Pena
      Franklin TN
    • Karim BELHEDI
      April 20, 2020 at 3:28 AM
      Anilda,
      if you want that the cost of the item include the charge of the transfer, you have to do a customisation. it isn’t in standard flow.
      Karim BELHEDI
      SPX CONSULTANT
      TUNISIA
      Karim BELHEDI
      spx
    • Steve Carter
      April 17, 2020 at 10:33 AM
      Hi Anilda,
      Unfortunately, the issue is that transfer orders don’t allow adding charges to item cost. So the cost you see of $32.29 after the transfer is the current cost (assuming there was no other inventory there at a different cost before the transfer) for that warehouse. I’m also assuming you are costing at the warehouse level. So the cost on the item on your Sales order is only the current cost ($32.29). Since you’re using moving average cost method, there would be no inventory close to make any changes either (moving avg changes happen in real-time).
      Steve Carter
      PCS Senior Consultant
      Blue Horseshoe
      Carmel IN
    • Anilda Pena
      April 17, 2020 at 5:58 PM
      Steve,
      I misspoke, we use Weighted avg. as our inventory model and run recalculations at the end of each month.Ā  Our inventory cost includes the charge which is added at the time of product receipt.Ā  I am curious where does the inventory cost derive from on a transfer order?Ā
      Thank you for your input.
      Anilda Pena
      Franklin TN
    • Steve Carter
      April 20, 2020 at 12:20 PM
      Hi Anilda,
      Thanks for the info on the correct costing method of moving average. That may make a difference. Can you also confirm these config questions?
      Ā – Are both warehouses in the same site?
      Ā – Are you costing at the warehouse level?
      Ā – Is the charge code set to debit the Item, rather than Ledger?
      Ā – Was there any inventory quantity for the item at the receiving warehouse before the transfer?
      Steve Carter
      Blue Horseshoe
      Carmel IN
The discussion ‘D365 F&O Inventory Cost and Transfer Orders’ is closed to new replies.
