Customer Invoice not available
  • Customer Invoice not available
    Posted by nazimlalji@hotmail.com on September 12, 2017 at 6:26 pm
    • Najeem JanatAli
      September 12, 2017 at 6:26 PM
      HI
      While applying the payment to Customer open invoice, system keep giving the message “Invoice not available for payment” Although its reflecting as open invoice and in the past payments were made to same Customer and it worked, with same set up its not working now
      please advise
      thanks and best regards
      Nazim Lalji
    • Ludwig Reinhard
      September 13, 2017 at 12:30 AM
      ?Hi Nazim,
      Can you compare the invoice where you have the problem with the one that worked previously in the customer transactions form?
      Probably some parameters / date settings, such as the due date, the approval parameter, payment release date, etc. prevent you from selecting it.
      Best regards,
      Ludwig
      Ludwig Reinhard
      SYCOR GmbH
      Goettingen
    • Stacy Black
      September 13, 2017 at 9:21 AM
      Nazim,
      This transaction has been marked for settlement by someone else in another journal or the open transaction editing.Ā  To find out where it has been marked, you will need to need to navigate to the Customer “Settle open transactions”Ā  (Customer> Collect> Settle> Settle open transactions).Ā  Then using the Inquiry dropdown in the action bar, select specifications.Ā  Using the radio buttons in the VIEW section until you see the transaction in the lower section.Ā  This lower section will tell you what type of transaction it is located in and the voucher/journal number.
      Stacy Black
      Senior Application Consultant
      mcaConnect
      Denver CO
    nazimlalji@hotmail.com replied 7 years, 12 months ago 1 Member · 0 Replies
The discussion ‘Customer Invoice not available’ is closed to new replies.
