Customer Invoice Emails
Posted by DSC Communities on July 24, 2018 at 10:53 am-
Michelle Jones
MemberJuly 24, 2018 at 10:53 AM
?We have several customer set up with email addresses for their invoices.Ā The email addresses are set up in print management.Ā When our branch locations generate the invoice, is there a way to default the printing to only select the print management option on customers that have the invoice email set up?Ā Currently our locations have to keep a list of customer who require emailed invoices and alter their invoice printing each time they go to invoice a customer that does not want emailed invoices.——————————
Michelle Jones
Staff Accountant
Redneck Trailer Supplies
Springfield MO
If you want to be super smart, you can use this blog to set up print management with a condition that effectively says – if an email is set for customer, send them email, but if none is set up do not attempt to send email.
https://dyntips.com/2016/08/30/e-mail-invoices-with-a-smarter-dynamic-print-management-setup/A simple method – you can flag your customers (let’s say by “Line of Business” with one of 2 values of “Send Email” and “Do Not Send Email” (this is easy to track, mass modify, manually modify)
Then you can set 2 print management records, one for the “email” customers to send them emails, and the other to simply print the invoice.
Zvika Rimalt
Functional Consultant
Vancouver BC
Many thanks for the replies, we will review.
Very best.
Lori Holmes
NJ Chapter Leader
AXUG Board of Directors
Hamamatsu Corporation
Bridgewater, NJ
LHOLMES@hamamatsu.com
Richard Wu
MemberJuly 25, 2018 at 6:01 AM
In print management, there is a “Do not print” flag that you could use if you don’t want to customize the printing.Ā You’ll have to do this for each customer (but only once unless they change preferences).Ā Go to customer > Print management > Expand Account / Documents / Customer invoice > Right-click “Original <Default>” and click “Override”.Ā Then check the “Do not print” option.Ā Or you can select other options that prevent the e-mail from getting to the e-mail on the account (put a dummy e-mail for example) so that in the event you do need to print an invoice, the “Do not print” option will not prevent that.——————————
Richard Wu
Bicon, LLC
Boston MA
Carol Holmes
MemberJuly 25, 2018 at 9:49 AM
Richard-
I was hoping that was in 2012 R2 CU7 – but it doesn’t appear to be. What release are you on?thanks,
Carol——————————
Carol Holmes
Business Systems Supervisor
Vesta Solutions, Inc.
Temecula CA
Richard Wu
MemberJuly 26, 2018 at 5:56 AM
Print management should be in there for all 2012 versions.Ā According to Microsoft: “Applies To: Microsoft Dynamics AX 2012 R3, Microsoft Dynamics AX 2012 R2, Microsoft Dynamics AX 2012 Feature Pack, Microsoft Dynamics AX 2012”Print management setup (form) [AX 2012]
Richard Wu
Bicon, LLC
Boston MA
?There is, but it increases the complexity of the print management setup quite a bit.
With print management, you can setup a rule on a transaction, a customer, or at the module level.
The smallest change to what you describe, is to set your module level print management to print somewhere, then for each customer that wants it emailed, go to that customer’s print management and setup an override to the module level setting that goes to email.You may want to put a cc on the emails to go to a shared mailbox at your company, so you can be sure the email went out as expected.
It is possible to setup rules at the module level that use the advanced query filters to send the emails whenever you put an email on the customer, but out of the box the feature is very delicate. We typically add a couple small customizations to make it more reliable.
Tony Zeigler
Senior Consultant
Strategic Solutions NW, LLC
Beaverton OR
Ryan Sorenson
MemberJuly 25, 2018 at 4:05 PM
Check out this link, it might help:——————————
Ryan Sorenson
Sunrise Technologies
Riverton UT
?Hi Michelle…we recently started using print management to email invoices for select customers.Ā Some customers want their invoices emailed, some want them snail mailed, while some have a portal we need to submit on.
We are batching our invoices and using print management when the batch job runs.Ā Our batch job runs on a 15 min interval.Ā So as shipments occur, invoices are either emailing or printing every 15 minutes, automatically with no user intervention.
Feel free to message me…
Lori——————————————-
Jessica Vaughn
MemberAugust 3, 2018 at 6:57 PM
Hi Michelle,
We set this up in both our R2 environment, and now in D365 as well.Ā If a customer wanted their invoices emailed, we set up their email address with a purpose of “recruit”.Ā We weren’t using this purpose for anything else, so we made it our “email invoice email” (we could then leave multiple other contact email address set to invoice for record keeping).Ā We set the module level print management to print to a printer, then used the customer specific override print management functionality to email to contacts with purpose of recruit.Ā We then set up the invoice batch job to use print management settings.Ā It would then email those customers who had an email set to a contact purpose of recruit and the override set up, and if not, it would print the invoice.Ā I’m pretty sure we were CU7- so I’m thinking you should have all of this functionality!——————————
Jessica Vaughn
Magpul
Louisville CO
Hi all…we are looking to add more details to the emails which are sent directly from AX to our customers.Ā Right now the emails being sent are very generic.Ā Ā The email contains a recipient, a generic subject and a PDF attachment.Ā All based from print mgmt settings…
Does anyone send emails which are more ‘personal’?Ā Perhaps including the customers PO’s number in the subject and body of the email?Ā If so, how did you do it?
Thanks.
Lori Holmes
NJ Chapter Leader
Bridgewater, NJ
Barr Snyderwine
MemberSeptember 19, 2018 at 8:40 AM
The emails are generic, we did a lot of customizations to improve the emails, The formatting and adding text is fairly easy. We had to add data to the emails and had to link out to tables and at time other tables not already attached to the email.Ā
We also wanted to route the emails to different users and copy to other users. We were able to most of the work ourselves (when I was a user)——————————
Barr Snyderwine
Business Solution Architect
Avanade
Middletown MD
Lynn Litzau
MemberSeptember 19, 2018 at 9:51 AM
Hi Lori,There are email templates you could pursue which will provide you with the flexibility to create customized verbiage in the body of the email.Ā Here are a few articles which might point you in the right direction.Ā Hope it helps!
Creating Automatic Email Confirmations From Dynamics AX
Configure email functionality in Microsoft Dynamics AX
Lynn Litzau
Stoneridge Software
Barnesville MN
Sanja Kolundzija
MemberJanuary 22, 2020 at 5:57 PM
Hi Lori,Ā
One search brought me to your question. I don’t know if you found a way to support your requirement for the more ‘personal’ emails. There is a free tool Docentric AX that brings lots of improvements in processes around D365FO report distribution. Feel free to message me or check this page for more info: https://ax.docentric.com/d365-how-to-manuals/d365-report-print-destinations/report-emailing-capabilities/
Sanja
Sanja Kolundzija
Software Architect
DOCENTRIC D.O.O.
Hi Sanja thank you.Ā Unfortunately, we are on 2012 RTM.Ā My previous understanding is that Docentric requires R2.Ā If that has changed, please let me know.
Best regards,
Lori Holmes——————————
Lori Holmes
Bridgewater, NJ
DSC Communities replied 7 years, 2 months ago 1 Member · 0 Replies -
The discussion ‘Customer Invoice Emails’ is closed to new replies.
