Connecting to External Database through AX 365
  • Connecting to External Database through AX 365
    Posted by DSC Communities on September 23, 2019 at 5:31 am
    • Gokul G
      September 23, 2019 at 5:31 AM
      Just like we used to connect to external Database through ODBC in AX 2012, is there a way to connect to external database in AX 365 ?
      If there is way to connect to external database through AX 365, Kindly share the details on how to achieve the same.
      Gokul Gopalakrishnan
    • Steeve Gilbert
      September 23, 2019 at 12:30 PM
      Simply use theĀ System.Data.SqlClient library just like you would in a standard C# project.
      https://docs.microsoft.com/en-us/dotnet/framework/data/adonet/ado-net-code-examples#sqlclient
      The “bad” thing is that if you are using D365 cloud, then your external DB needs to be visible to D365, which means being exposed to internet.
      Steeve Gilbert
      Software Development Supervisor
      Boa-Franc S.E.N.C.
      QC, Canada
    • Gokul G
      September 25, 2019 at 12:26 PM
      Thank you Gilbert !!
      Gokul G
      ONECECO
    • vishal Dhawgaye
      September 25, 2019 at 5:52 PM
      Hi Gokul,
      Check ‘ResultSetHelper’,Ā  ‘ResultSetHelper’ classes in D365. these classes also connecting to external database.
      vishal Dhawgaye
      Hitachi Solutions America, Ltd.
    • Chaitanya Golla
      October 2, 2019 at 2:06 PM
      If your external database is on Azure then probably you can use BYOD(Bring Your Own Database) feature of D365FO.
      Please refer below links for setup and usage:
      (Bring Your Own Database(BYOD) in D365FO – Setup)Ā
      https://www.axug.com/blogs/chaitanya-golla/2018/07/26/bring-your-own-database-in-d365fo-setup
      (Bring Your Own Database(BYOD) in D365FO – Data entity Publish )
      https://www.axug.com/blogs/chaitanya-golla/2018/07/26/bring-your-own-database-in-d365fo-publish-entity
      Bring Your Own Database(BYOD) in D365FO – Export data
      https://www.axug.com/blogs/chaitanya-golla/2018/07/26/bring-your-own-database-in-d365fo-export-data
      Chaitanya Golla
      Lead Architect
    • Gokul G
      October 2, 2019 at 2:24 PM
      I am already aware about BYOD part. In my case it’s an ON-PREMISE database.
      Hence BYOD wont apply over here.
      Gokul
      Gokul G
      ONECECO
The discussion ‘Connecting to External Database through AX 365’ is closed to new replies.
