We use MS Dynamics AX 2012 R2 and we discovered the financial dimensions of a purchase requisition were incorrect after the requisition was approved through workflow and after the purchase order was generated.Ā We haven’t received the item or the been invoice, so no entry has been made yet to our general ledger.Ā Is there a way to change the financial dimension of a purchase requisition after it has been approved in workflow so the correct dimension post when the item is received and invoiced?
—————————— Brad Reeves Supervisor – Financial Accounting Bill And Hillary Clinton National Airport Little Rock AR ——————————
Ankit is right, once the requisition is closed, it is not editable, so the change would have to happen on the PO using change management workflow, etc.
—————————— Shirley Adams AKA Enterprise Solutions New York NY —————————— ——————————————-
Ankit Modi
March 22, 2018 at 8:04 AM
System will allow to change financial dimension on purchase order to post correct financial dimension while doing receipt and invoice.
Is there any specific reason to change the financial dimension on purchase requisition.
