Change of AX user domain:
Posted by nazimlalji@hotmail.com on June 12, 2019 at 12:27 am-
Hello All
We have a change of Domain for the AX users in Dynamics AX 2012. For Example from ABCJsmith to XYZJSmith
Should we delete ABCJSmith and import XYZJSmith, which I dont think good practice as there are transactions attached
When we are importing as XYZJSmith user ID appears as JSmith1
Any suggestion
Thanks and kind regards
Katja Schebler
MemberJune 13, 2019 at 8:49 AM
?Hello Nazim,I did a similar task in AX4, but the fields should be the same in AX2012. Important to know is that each user has a SID of active directory AD. it is a long string like S-1-5-21-4……… I guess that each Domain has own SIDs.
What I did was to get the SIDs of the users of the NEW Domain and put it into a new staging-table, together with the new networkalias and the user-ID (which does not change). Maybe your networkalias is the same like your old ones.Then I updated the userinfo-table with the data from the new staging-table via SQL. Please test it in a test-system.
update dbo.USERINFO
set networkdomain = c.Networkdomain_new, — = the new network domain
Ā SID = c.SID_new,Ā Ā Ā Ā Ā — = the GUID
Ā networkalias = c.networkalias_new — = the AD-user
— select id, networkdomain, sid, networkalias
from dbo.USERINFO u
inner join schebler.dbo.userconversion c
on u.id = c.id
and u.networkalias = c.networkalias_old— check that each networkalias is unique. the query result should get no lines
select networkalias, count(*)
from USERINFO
where enable = 1
group by networkalias
having count(*) > 1Kind regards,
Katja Schebler——————————
Katja Schebler
NORMA GROUP Holding GmbH
Maintal/Germany
Randy VanDeMaat
MemberJune 13, 2019 at 8:50 AM
I have the same issue in AX 2009, we are moving domains and I have to change all users to the new domain. If you delete and import new, not only do you lose the User relationship to transactions, the users would lose favorites, saved queries, usage data ect…We have written a job in AX to change the domain of the user. You can modify it slightly to just do specific users by adding criteria for UserInfo.NetworkAlias.
static void MM_ChangeUserSID(Args _args)
UserInfo UserInfo;
str alias;
sid userSid;
str domainName;
xAxaptaUserManager mgr;
xAxaptaUserDetails det;ttsbegin;
breakpoint;
while select forupdate userInfo
where userinfo.networkDomain == ‘oldnetworkdomain’
info(userinfo.sid);mgr = new xAxaptaUserManager();
alias = userInfo.NetworkAlias;
domainName = userInfo.NetworkDomain;// Get the single user’s details from the kernel class
det = mgr.getDomainUser(domainName, alias);// If Admin alias/domain are getting changed, update SID
if(det && det.getUserCount() > 0 && det.isUserEnabled(0))
userInfo.networkDomain = ‘newnetworkdomain’;
userSid = det.getUserSid(0);
userInfo.sid = UserSid;
userInfo.update();
info(userinfo.sid);}
ttscommit;
Randy VanDeMaat
Micro Matic USA Inc.
Brooksville FL
Mark Prouty
MemberJune 14, 2019 at 9:33 AM
Test this –
Disable user. ?Change domain reference & email (could use script for mass change).
Re-enable user. AX will search for & apply new SID.
Retains all user last used settings, user ids, etc.
SharePoint might be trickier. I have notes somewhere if you need.——————————
Mark Prouty
Programmer / Analyst
ANGI Energy Systems
Janesville WI
nazimlalji@hotmail.com replied 6 years, 3 months ago 1 Member · 0 Replies -
The discussion ‘Change of AX user domain:’ is closed to new replies.
