BYOD – General Journal Account Entry Entity
  • BYOD – General Journal Account Entry Entity
    Posted by DSC Communities on August 27, 2020 at 5:16 pm
    • Eric McMahon
      August 27, 2020 at 5:16 PM
      HiĀ
      We’re currently on version 10.0.11 and using BYOD to export General Journal Account Entry Entity (daily 60k records).Ā  Incremental push no longer works, we’ve had to move to full push which also regularly fails but gets fixed by dropping entity.Ā  Has anyone else had issues with this entity?
      One of the proposed solutions (apart from moving to 10.0.12) was to use a new entity General Journal Account Entry Reporting however testing on this has also been unsuccessful.
      Regards
      Eric
      #Financeandoperations #BYOD
      Eric McMahon
      Brisbane
    • Joe MacPherson
      August 28, 2020 at 7:17 AM
      Hello Eric;
      You’re not alone on the BYODB Incremental Export woes…Ā
      We experienced these challenges early on in our D365 journey starting with v7+, through v8+ and onto v10+…
      Our record volumes were just too high to execute a full nightly export across multiple Entities; our solution was to build our own Incremental process through the following steps: (high level overview)Ā
      1. Creation of an ‘Azure’ (BYODB) Production database
        1. Onetime Full Entity export to populate the Production database Entity tables
      2. Creation of an ‘Azure’ (BYODB) Staging database
      3. Nightly Data Management Export projects with Entity specific filtering on targeted key fields (Created/Modified date)Ā
        1. Entities have to be reviewed for key target filtering fields
      4. Custom Stored Procedures to “Merge Into [AX_PRODUCTION].[dbo].[GeneralJournalAccountEntryStaging] as Target”
      5. SQLAgent execution jobs to validate that the ‘filtered’ Entity was in a READY state and then Execute the MERGE Stored procedure
      Be more than glad to talk this through off line if you desire.
      Joe
      Joe MacPherson
      Coldwater Creek
      Hingham MA
    • Sarah Poe
      August 28, 2020 at 3:10 PM
      Hi Eric,
      We also had an issue with this entity, and many others.Ā  We ended up having to create custom entities.Ā  If you need more information, please feel free to reach out directly.
      BYOD has been a big struggle for us, so we feel your pain!
      Sarah Poe
      Luck Stone Corporation
      Richmond VA
    • Eric McMahon
      August 29, 2020 at 1:57 AM
      Thank you Sarah & Joe. Despite strong advice not to go the custom entity route we may need to do that as well as some filtering.Ā  I’ll let you know how we go.
      Regards
      Eric
      Eric McMahon
      Senior Advisor
      Queensland Treasury Corporation
      Brisbane
    • Eric McMahon
      October 9, 2020 at 3:49 PM
      Glad to report our issue was resolved and now runs in less than a minute (60k rows per day incremental load). The MS backend team discovered that the query planĀ on the table was was sub optimal and updated statistics to force a better query plan. On going a full scan is set with Persist_sample_percent set to on. It’s been running successfully for a number of weeks now. ??
      Eric McMahon
      Senior Advisor
    DSC Communities replied 5 years ago 1 Member · 0 Replies
The discussion ‘BYOD – General Journal Account Entry Entity’ is closed to new replies.
