BOM line delete
  • BOM line delete
    Posted by DSC Communities on February 1, 2017 at 8:21 am
    • Mark Berg
      February 1, 2017 at 8:21 AM
      We are in the process of upgrading from 4.0 to 2012 R3.  During testing we have discovered that we are not able to delete multiple lines from a BOM.  Even as the system admin I am unable to do it, 4.0 allowed it and we use it.  I have not found any parameter settings that control this.  Any suggestions on where to change this or any workarounds?
      Mark Berg
      ERP Coordinator
      Bay Industries Inc.
    • Archive User
      February 2, 2017 at 7:30 AM
      The delete “X” on the BOM lines indeed is not selectable if you select more than one BOM line on the form …. however the keyboard shortcut to delete still works šŸ™‚
      Just hit “Alt F9” and it will delete everything selected
      Matt Dickson
      Business Analyst
      Lawrenceville GA
    • Mark Berg
      February 3, 2017 at 11:45 AM
      Thanks for the help.  Alt-F9 works.
      Mark Berg
      ERP Coordinator
      Bay Industries Inc.
    • Erik Kornerup
      February 2, 2017 at 1:30 AM
      Hi.
      Interesting – upgrade from 4.0 to AX 2012 – I would call it a reimplementation šŸ™‚
      Do you want to delete from a for form or from code?
      What errors do you receive?
      If you look at the standard form for BOM the BOM versions can be deleted,
      while the BOM lines can’t be deleted before the BOM versions are deleted.
      Erik Kornerup
      CGI Denmark
      Ballerup QC
    DSC Communities replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘BOM line delete’ is closed to new replies.
