Bank document type is inactive – Letter of Credit
  • Bank document type is inactive – Letter of Credit
    Posted by DSC Communities on February 22, 2018 at 2:51 pm
    • Lisa Ng
      February 22, 2018 at 2:51 PM
      Hi All,Ā
      I’m trying to place a PO with the Letter of Credit.Ā  The Bank document type is inactive.Ā  How do activate it; so that I have a dropdown box to choose Letter of Credit?Ā  Thanks so much!Ā  Ā
      Lisa Ng
      Business Analyst
      HOUSTON TX
    • Nirav Modi
      March 5, 2018 at 1:03 AM
      ?Good day Lisa,
      as Ludwig mentioned, the Letter of credit will be enabled on Purchase and sell from Cash&Bank Module Parameter –> General –> Bank Document –> Enable Letter of Credit for Import and Enable letter of Credit for Export.
      Nirav Modi
      Project Manager – Ax
      Indusa HQ – USA
      00919426381531
    • Lisa Ng
      March 9, 2018 at 5:51 PM
      Thank you, Nirav, for your response.Ā  these two boxes have been checked and the Bank document type is still inactive.Ā  Ā Does it have anything to do with documentĀ management?Ā Ā
      Lisa Ng
      Business Analyst
      NA
      HOUSTON TX
    • Ludwig Reinhard
      March 11, 2018 at 1:20 PM
      Hi Lisa,
      Can you edit the PO and manually select a bank document type other than ‘none’?
      Best regards,
      Ludwig
      Ludwig Reinhard
      Sycor EMEA
      Goettingen
    • Lisa Ng
      March 12, 2018 at 9:17 PM
      Hi Ludwig,Ā
      Thank you for your response.Ā  I happened to delete that PO, but I created a new one.Ā  The Letter of credit/import collection is still inactive. Ā
      Lisa Ng
      Business Analyst
      NA
      HOUSTON TX
    • Lisa Ng
      March 16, 2018 at 12:57 AM
      All,
      The solution is found.Ā  I need to share this in case anyone runs into the same issue
      My Purchase type is JournalĀ (screenshot 1) which caused the Bank document to be inactive.Ā Ā
      When switch to Purchase order, the Bank document is now available for Letter of Credit.Ā Ā
      Lisa Ng
      Business Analyst
      NA
      HOUSTON TX
    • Ludwig Reinhard
      February 27, 2018 at 4:00 AM
      Hi Lisa,
      Please check your bank module parameters.
      There are some specific parameters available in the general tab of the parameters form that you have to activate first.
      Best regards,
      Ludwig
      Ludwig Reinhard
      Sycor EMEA
      Goettingen
The discussion ‘Bank document type is inactive – Letter of Credit’ is closed to new replies.
