We are on Dynamics AX 2012 R2 CU7.Ā Ā We would like to start backflushing on some of our raw materials but are not certain how aĀ batch number is selected when multipleĀ batch numbers exist in the staging area?Ā Is it by FIFO?Ā
Aaron
—————————— Aaron Robinson Sr. Business Systems Analyst Stone Brewing Co. Escondido CA ——————————
Batch reservation on the production order with back flushing reserves materials based upon the setup in the Item Model Group.Ā Within the Item Model Group you can specify to use FIFO or FEFO reservation based on if you’re using expiration dates or not.Ā Then you will need to make sure the reservation parameter setup at Product Control Parameters is set to something other than Manual so that the batch is auto-reserved during the production order process.
Jonathan
—————————— Jonathan Anderson Managing Consultant BKD Technologies Denver CO —————————— ——————————————-
Robert Stogner
October 24, 2017 at 8:15 AM
Are you using WAX?Ā Read this article about how releasing production orders to the warehouse for picking to staging works that also relates to batch controlled items.
