Azure build pipeline error after deleting unused model (‘No descriptors could be found for model’)
  • Azure build pipeline error after deleting unused model (‘No descriptors could be found for model’)
    Posted by DSC Communities on February 23, 2022 at 8:07 pm
    • Jack Ogle
      February 23, 2022 at 8:07 PM
      We use an Azure pipeline for F&O package builds and we recently deleted a model our MS partner had created because it was not being used. The build pipeline now fails the X++ Compile step with the error:
      D:a10NuGetsMicrosoft.Dynamics.AX.Platform.CompilerPackageDevAlmMicrosoft.Dynamics.Framework.Tools.BuildTasks.targets(19,5): Error : No descriptors could be found for model ‘[PartnerModel]’ in metadata directory ‘D:a10sMetadata
      Does anyone know where we need to remove a reference to this model in the build configuration?
      Jack Ogle
      DFW Heavy Duty
      Forth Worth TX
    • Ben Morgan
      February 24, 2022 at 7:40 AM
      Hi Jack,
      I’m not sure what steps you’ve already taken in this process so some of this might be redundant, but here are the steps I usually take when creating or installing customizations for compilation through the pipeline.  My assumptions for these steps are that you have a source development machine where you do the work in Visual Studio and a destination machine that the pipeline compiles to, with a merge process that determines what the pipeline uses for that compilation.  Here are our applicable steps:
      1. Azure DevOps > Repos: Remove the associated model folder
      2. Visual Studio (RUN AS ADMINISTRATOR):
          a. Source Control Explorer: Right-click > Get latest version on /Trunk/Main/Metadata (or whatever your path is)
          b. This will apply the deletions
      3. Stop 4 services (also stop VS IIS express):
          WWW Publishing Service
          Microsoft Dynamics 365 Data Import Export Framework
          Microsoft Dynamics 365 Batch Management
          Management Reporter 2012 Service
      4. Manually delete any remaining model-associated folders from K:AosServicePackagesLocalDirectory
          a. DO NOT DELETE ANY MS FOLDERS
          b. You will likely need to close VS to complete this
      5. Visual Studio (RUN AS ADMINISTRATOR):
          a. Dynamics 365 > Model Management > Refresh Models
          b. Pending Changes > Check in
          c. /Trunk/Main/Metadata: right-click > Branching and Merging > Merge
              i. Selected changes
              ii. Select all changes related to this deletion
              iii. If prompted for conflicts, take newest version
          d. Dynamics 365 > Synchronize database [you may not absolutely need to do this, but it sometimes has a surprising impact on what ends up in the pipeline]
          e. Pending Changes > Check in [this is where the changes will affect the pipeline]
      6. Restart services (see above)
      7. Run build pipeline in Azure DevOps
      Hopefully something in there will help.
      Best,
      Ben
      BENMORGAN
      520.293.1488 ext. 7472
    • Jack Ogle
      February 24, 2022 at 3:51 PM
      Thanks for replying Ben. I was able to resolve the issue by removing a project referencing the model in the solution set in the Build solution step of the pipeline. I updated the solution in Visual Studio, checked it in and that triggered the build. It completed without errors.
      Jack Ogle
      DFW Heavy Duty
      Forth Worth TX
    DSC Communities replied 3 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Azure build pipeline error after deleting unused model (‘No descriptors could be found for model’)’ is closed to new replies.
